Cut the zork stinger and added stainless wastegate pipe- like we debated
Ok guys I finally stopped cutting the zork back so it looks like it should IMHO. I modified a SC lower valance to fit the 930 and center cut it. I also added a SS wastegate pipe to fill (sort of) the empty left opening. What do you think? Its loud and I noticed that the boost comes on 1K RPM eairlier. FerrairPete was right- It's loud and "look at me officer". We blasted the car up to the boat for an hour each way and it was a hooot. Their was no sneaking up on anyone thought....- regards, Mike
Started out like-----------
NOW IT LOOKS
NOW IT LOOKS
Very nice... I am in the process of doing final fitment of my zork and a 934-style wastegate dump pipe that runs along side of it. Need to do a little trimming myself. What did you use to cut the pipe? I ordered a fiberglass rear valence that I'll cut to accomodate once the pipes are all where I want them.
And yes... REALLY loud.
With the fiberglass valance make sure to keep the heat shield. I was amazed how hot that little zork gets....Mike
thanks for beating me to the explanation jitters.
i agree, his comment on the boost arriving sooner is related to the deletion of the skok system and the addition of the less restrictive zork.
And you are not mistaken about the boost coming in sooner.. Turbos don't like back pressure.. when you remove the stock muffler and go free flow they get zippier. Zork flows even better with zero restriction!
Glad to hear you're making race-car noises!
Paul
