911 Turbo (930) Forum 1975-1989
930 turbo spacers
Old 10-15-2007, 05:48 PM
markcoznottz
markcoznottz's Avatar
Default 930 turbo spacers
What are these 'spacers' on the rear? wheels. Is it safe to remove them I presume the wheel hub will mount deeper without them. Im assuming 964s didnt have them because the rear offset is less on these cars.
Old 10-15-2007, 10:40 PM
A930Rocket
A930Rocket's Avatar
You can remove them, but you need to be aware of the wheel offset. Removing the spacer will cause your wheel to move in by about an inch. Also, depending on your calipers, you may need spacers or a different offset.
Old 10-16-2007, 01:43 AM
ayglass
ayglass's Avatar
Mind the length of the wheel studs too! If you are running cap-type lug nuts they will bottom out...
Old 10-16-2007, 09:25 AM
Dickyboy
Dickyboy's Avatar
Looking at this from another view, I'd like to add spacers. I have original fuchs on my '86, what are the potential pitfalls of adding spacers and where can I buy them?
Thanks Rich
Old 10-16-2007, 01:04 PM
markcoznottz
So would removing the rear spacers give me a visual offset similar or the same as the 964 rs 3.8? That was turbo bodied but used, presumably non turbo trailing arms (ie not the 964 turbo arms). If i approach cargraphic to make up some 11 inch rears for a 930 turbo would they ask me if i had removed the spacers? its kind of confusing.
Old 10-16-2007, 02:45 PM
nathanUK '81 930 G50
nathanUK '81 930 G50's Avatar
I have no spacers on my 930, the wheels were custom made.
Old 10-16-2007, 10:36 PM
A930Rocket
A930Rocket's Avatar
If they don't ask, you need to tell them. Doing this will make a wider outside wheel half. A good look I think.
Quick Reply: 930 turbo spacers
