Oil drain plate with drain plug
I really dont know what it is called, but it is the plate that the drain plug goes into. I had some work done under the car and when they jacked it up they damaged the drain plate. Does anyone have an extra to sell. I want the one with the drain plug built in. You can get them without the drain plug. I dont want that one. Thanks Jon
It's just called a cover. Actually you need several pieces and since the idiots used the cover as the jack point, I would make them pay for it - OEM parts:
930 101 902 00 Cover
930 107 313 00 Oil Strainer
911 107 176 03 Screw (Drain Plug)
plus gaskets for the cover and a seal ring for the drain plug. Call your local P dealer and let them order the full set.
