Tire size question
Tire size question
Lindsey will be finishing my P3's in a couple of weeks and I am curious about what size tires you guys think I should run. The wheels are 9X17 fronts and 10X17 rears.
I've discovered the following when I did some research and this is what I plan to run when I get P2s:
17-35-315 for the rear
17-40-255 for the front
However, I was planning to run 11" wide rims in the rear.
I've heard many say that you can a 275 up front, but you might encounter some rubbing on the foot well on hard/sharp turning...you might also need to roll the fender.
some good info here...even from our beloved diabolos88:
http://forums.pelicanparts.com/showt...hreadid=292097
Shop Rat
Dave Lindsey should be able to advise you on the best sizes for the wheels. He advised me to get 245/40/17 for my front 9's and 315/35/17's for my rear 11's.
Originally Posted by jwl
Thanks for the input guys! I can't wait to get these POS AZEV's off and the P3's w/ Goodyear Eagle F1's mounted up.
