rear electrical box, what is this stuff for?
What are each of these items for? Trying to get rid of some old wiring/components that are not being used.
#4 looks like two big capacitors, maybe for old CD ignition?
#2 is the is the ignition cut-off relay:
https://rennlist.com/forums/911-turbo-930-forum/288234-engine-runs-on-as-a-safety-feature.html
Yea, I hear ya on the two D batt's. That's exactly what they looked like as I was unwrapping 24 year old electrical tape!
So what is an "air flow sensor/charging pressure relay"? Does that have something to do with the plug you remove to make the fuel pumps work with the car off?
car is an 82
car is an 82
Mine is square and yellow, but with the ignition on and you press down on the air flow meter plate, it trips a switch and kicks on that relay. It's a safety device. When there is no air flowing, the pumps stop. If you are EFI, I would assume you don't need it.
car is an 82
car is an 82
