"While You're In There..."
As I read through this, it's occured to me that nearly every guy that has claimed they only wanted a 300HP, dependable, driveable, maintaneable 930, have ALL probably fallen into the abyss that I have suddenly fallen into! It reminds me of my sick two channel audio habbit..."The Audio Spiral" they call it!
Lastly I'm reminded of an old Richard Pryor routine: "...no sir I don't touch it...I peepee with it, and that's it..." YEAH RIGHT!
Stephen, you remind me of a crystal-meth dealer...pedaling your hi-performance, hi-quality Porsche wears on the poor, pitiful, addicts like myself! How do you sleep at night? Dayum, I need a fix...BAD! I'll gladly pay you Teusday for a set of 3.4 Ps&Cs today...
I had two thought's about your question, you don't have much to spend, you hope to never open up the engine again.
If you would like to go further in the future how about getting your heads ported out to match a 3.2 carrera manifold while it is in pieces (you have the ARP stuff and are gonna have your rods done nice).
Is there any advantage in doing higher capacity oil pumps (in & out) so that you could use larger diameter squirters, would this help reduce cylinder and/or piston temps keeping further away from detonation ? (If so could the ignition or boost be increased for more performance ?).
Love the idea of doing the heads for twin plug.
Surely the cams can be changed by just lowering the engine (partial drop).
I'm deffinately going with the SC cams, now. Next, I'm looking into the finned cylinder issue. We'll see what L&N says about pricing for "Nickies".
I would go twin plug as well. Then when you are ready get a set of twin bosch coil packs, dump the distributor and get it programed with an ECU- you can get the coil packs from a scrappy next to nothing. i am in the process of doing this to mine but only single plug at the mo.
Originally Posted by Sameer
sand_man,
Just go for the regular Mahle or JE's, they are good enough, have them coated for better heat dissapation and your set to go. JMO.
When you factor in the little things like powder coating, new engine compartment sound deadening mat, new engine compartment engine seal, various oil lines...not to mention I don't even know what the machine shop will cost...this adds up VERY QUICKLY!
Don't forget to replace the fuel lines that run through the car.
Originally Posted by PorschePhD
It is a slippy slope. It doesn't get better either.
I started my rebuild a year ago with a $9000 budget (rebuild consumables, new misc parts, IC, ECU, machine shop, .....). During the first six months,, the "while you are there" syndrome was firmly in place. When the car started, I was double the budget. Little things like silicone hoses, fittings, stainless braided lines, aeroquip fittings (yikes!), coatings, and on and on....
It's now six months later, and I am still spending - just spent another $380 today in "refinements".
But it doesn't get any better turning the key on your project and it starts - then it runs! And then it runs better. Then there's the divorce... (kidding..kinda)
Any idea's about my idea's anyone ?
As for oil pumps, my opinion is that the stock tubo pump is just fine. What has changed to warrant an upgraded pump ($$$$)? Your gallies are the same size, the squirters are the same size, oil volume will stay the same, etc.
Piston squirters will help piston temp, but does very little for cylinder head temps. Therefore, based on the size of the squirters, you can not increase boost or ignition advance safely. You would be better adjusting AFR (slightly richer) to cool the chamber.
Advancing the iginition early is a benefit to spooling the turbo as quickly as possible, but once its up to speed, back off the advance to the provide optimal combustion (10 - 12 degrees ATDC if I remember correctly). In this scenario, boost is the key ingredient or killer (heat generator).
