911 Turbo (930) Forum 1975-1989
934 and 934.5 photos
Old 10-17-2009, 06:11 PM
  #76
turboguy934
turboguy934's Avatar
Default a few of my 934
for sale, call me 864.991.9762 i hate to let her go but my new business is draining me www.jakesperformancetowing.com
the numbers are stickers, they come off. the paint is 2-3 months old shes a runner call for details
Old 02-24-2013, 02:55 PM
  #77
piero
piero's Avatar
that mine
Old 02-24-2013, 04:32 PM
  #78
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
Bellisimo!
Some more photos of her would be wonderful.
Old 05-23-2017, 12:43 AM
  #79
Amber Gramps
Amber Gramps's Avatar
This is one of the aluminum roll cage 934.5.
http://canepa.com/museum/1977-porsche-934-5/
Old 09-12-2017, 10:07 PM
  #80
rsnodgrass
rsnodgrass's Avatar
Does anyone know what size brake discs the 934 used front and rear? Strangely, I can't find any references to this!
Old 09-13-2017, 01:41 PM
  #81
MUSSBERGER
uninformed gas bag
MUSSBERGER's Avatar
"The suspension was based on the standard 930 Turbo Carrera torsion bar suspension, but suplemented with Bilstein shock absorbers fitted with coil over springs. The suspension was stiffened by the addition of Delrin bushing on the front A arms in place of the rubber used on the series production car and in the rear they used a spherical joint on the inner end of the cast aluminum trailing arm and a ball bearing race around the outer end of the rear spring plate. The larger disc brakes from the 917 and Carrera RSR 3.0 were used with large radially vented and cross drilled brake rotors and the heavily finned aluminum calipers. The brake bias was controlled by a dual master cylinder pedal assembly with a bias bar adjustment. They also used the same center lock hubs that had been used on the Carrera RSR 3.0 They went to a sixteen inch wheel and tire combination to provide a larger foot print and adequate room for the large brakes. Because no Porsche cast magnesium wheels were available in the sixteen inch size they had BBS make modular wheels with a cast center for the 934s."
From an Article written by Bruce Anderson for 911 World
https://9lf.de/de/bremse/582-albert-...rennwagen.html
Old 09-13-2017, 11:47 PM
  #82
karmx7
karmx7's Avatar
The January 1977 issue of Road and Track had a nice comparison test between a 930, a 934 and a 935. They list the 934 and the 935 as having "12.0-in. vented and cross drilled discs front and rear".....
Quick Reply: 934 and 934.5 photos
