Running very lean on Boost
Aloha All,
Can you guys help me out.
Situation I have a 1983 911 Turbo with a Garrett GT35, Car has after market exhaust and headers.
At idle i got the car's AFR reading using Innovate gauge around @13-13.5
When crusing at 3000 RPM the gauge is about @15.7- 16.4
On Boost it slowly keeps going up so I let off the pedal because I am scared to blow the valves or the piston from running to lean.
Question: How do I get the AFR to drop into the @12 - 12.5 while on boost?
Thank you
James
Thank you
James
Hallo James,
schau mal oder?
Ich habe das video vor ein paar tagen gemacht, gruss dominik
ich habe einen k27, 7006 und einen Kokeln intercooler montiert.
Um noch bessere AFR-Werte (10.5-11) zu erhalten, bekomme ich einen Mod. WUR bauen.
Brian from RarlyL8 has a 112 adjustable WUR in stock.
