911 Turbo (930) Forum 1975-1989
Help starting 911 Turbo after storage
Old 12-25-2017, 04:15 PM
samfire1
samfire1's Avatar
Default Help starting 911 Turbo after storage
I need help, I have a 911 Turbo that sat in the garage for a little over a year. I kept the battery charged. what is the proper way? All I know is I need to take out the old gas. Now, how do I do that, Is there a drain plug in the gas tank? Does a siphon pump line make it to the bottom of the gas tank if done through gas tank opening? What about the gas lines and fuel pump? Should I use starting fluid after replacing gas and trying to start?
OverTake (05-26-2022)
Old 12-26-2017, 12:30 AM
MrFixedIt
MrFixedIt's Avatar
I had to use a generic fuel pump from Advanced Auto hooked up to a 12 volt supply to pump out most all of the 930's gas. That was for 2 year old gas. From what I understand, old gas burns fine but is hard to start, so by mixing it with new gas, you can safely use it. If you have half a tank, you might just add some fresh gas and it will probably drive fine.
Old 12-26-2017, 09:36 PM
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
I have one of these for my cars that don't see a lot of use. I like to keep full tanks of fresh fuel in them. Fuel I take out goes in the Cayenne.
https://www.gastapper.com/store/p1/GasTapper_Standard_-___In_Stock_-_Free_Shipping__USPS_Priority_mail_-.html
Quick Reply: Help starting 911 Turbo after storage
