Just had my 930 undercarriage detailed
A fellow rennlister recommended this dry ice cleaning process called cryo detail and I bit the bullet and did it on my 930 - check out the before and after pictures. Pretty amazing.
930 before
930 after!
930 before
930 after!
wow. That is incredible. You can see the plating on the brake calipers. I feel like it's a must do, what is approx. cost for something like this? How long does the process take? Time to fix the oil drips!
Thanks. There are three different stages depending on how bad it is and how much dry ice and time it will take. Low end cost would be around $1500, high end closer to $3000. Mine was somewhere in the middle and I also had my OEM exhaust cleaned because I save it and it was filthy. The process took about a week and they took over 20 pounds of grime and dirt off the car. 32 years worth! Hope this helps.
