Front Hub Grease Seals
Team Owner
I haddah Google dat
I use a soft redwood stick that I split off of a 2"x6" board from redoing the deck.
Just tap it out, and you might even be able to re-use it.
I picked up a Seal Puller last night, but there is no way I have enough leverage on the hub to pull it out right now. What I plan to do is bolt the old rotor back on the hub, and lock the rotor in a Bench Vise at my buddy's shop this weekend.
Team Owner
Wait, so there is a inner lip to tap out from the front side of the hub?? I wasn't sure since the inside of the hub is smothered in old grease. I didn't want to start hitting things that might not be the Seal itself...
Team Owner
slight hijack
i'm not sure if my quote captured Russ' pic but you see the white piece with the horn contact ? is it called the clock spring ? I need that part, anyone know where I could score one ? my copper wore out and I have an intermittent horn . I " rebent it " so there is a different part touching the wheel and that seamed to resolve it , but just wondering if anyone knows where I can get a replacement
I haddah Google dat
I haddah Google dat
slight hijack
Yes the Hubs are off the car, and separated from the rotors now, so yes the outer bearings are out too. I'd be afraid to start hammering down on the inner bearing just to tap the seal out, but that might end up having to happen if all else fails. I figure I'll be able to pull it out with the seal puller once I have the old rotor back on, locked in a bench vise. I'm sure its not in there too bad, it's just me not having any leverage at all right now... I need my own workshop already
I haddah Google dat
Apparently Bill Verburg knew you need to see my hubs and my seals:
http://forums.pelicanparts.com/porsc...1978-80-a.html
