Any Experience with Bridgestone RE-11 or Michelin Pilot Exalto PE2
Hi Guys,
I searched and didn't find much on these tires. Just wondering if anyone has owned them and what their experience has been with them? Its for a car which uses the same tire sizes as a 3.2 Carrera equipped with 16" Fuchs. Plus both cars have a rear weight bias so there are some similarities there too.
I'm looking at replacing Goodyear F1 GS-D3s (because of age, not mileage). I was originally going to replace the F1 GS-D3s with the RE-11s, but the head tech asked why Bridgestones, and showed me another customer's car that they just installed the michelins on. I mentioned it was a top rated max performance tire. He said the Michelins are highly rated, are probably quieter and may give a better ride. The PE2s seem to be a level down on tire rackes performance description (ultra high performance summer tire, rather than max performance tire on Tireracks catagory list), but this isn't a modern 400hp car. I don't Auto-X and I know that my car's performance levels today probably don't require the most extreme performance tires, but I'm not sure which way to go.
I searched the tire threads here and saw a brief mention of a Pilot Exalto. Anyone else using these tires that can share some ownership experience?
I did some research on tirerack's site and it appears the rear Michelins weight about 4-5lbs less each and I think the fronts weight 3-4 lbs less each. Less weight at each wheel is always a good thing. So less weight may cancell out some of the performance advantages of the RE-11, sharper turn in and higher ratings or handling in the dry weather (I think the Michelins are better in wet, although I don't use the car in wet weather).
Any thoughts or experiences with these 2 tires is greatly appreciated. I've had good experiences with both brands so I'm sure both are good tires.
Thanks and best regards,
Dino
P.S. There are some very beautiful examples of 911s on this forum. I'm definitely thinking about one day adding an air cooled 911 to our garage.
Dino
It has been a while and I can't remember what they were on, but I have driven a car on the track with RE-11's and I was impressed. That is about all I can say about them.
I've run the RE-11's on a couple of cars now, and have been very happy... Good looking tire, tons of grip... Ride isn't too harsh.. And they don't get noisy when they are worn down like some tires!!!
I've had the Exaltos on my '87 for about 2 years and they have performed well through 2 DEs and 2 driving schools and many road trips. They have a little over 15k miles. The rears are at the wear bars, the fronts are not far behind. They were much quieter than the BFGs that were on the car when I bought it. I liked them but might get something cheaper next time.
While not the tires you're looking at, I believe they're in the same class / price range... I was very happy with the Dunlap Direzza Star Spec on my 993. Very smooth on the street and great performance on the the track (for a street tire)... just offering another option.
Best regards,
Dino
