Headlights only work when pull turn signal stalk to hi-beam "flash-to-pass" position
As the title says, all of a sudden, my headlights only work when I pull the turn signal stalk to high-beam "flash-to-pass" position.
When I turn the headight switch on normally, nothing - no high-beams, no low-beams, no nothing.
Only when I pull back on the turn signal switch do I get headlights (high-beams, I assume).
The simplest reason would seem to be that the turn signal stalk switch is fragged...but, any other ideas?
Thanks!
Thanks!
Location: Manhattan Beach, California. Retired Engineer 1986 Targa-Factory Delivery Original Owner
Stalk.
Thanks!
Thanks!
You might also install the headlight relays as per the attachments.
Good luck,
Gerry
+ 1 on the stalk being the problem. I just replaced mine on my 75 911 and unti it'sl replacment had never noticed how sloppy my old signal stalk had become compared to a new unit. Good luck !!!
