1988 pedal positions
Hello Folks,
Today was the first time I ever drove any air cooled 911. I tested a 1988 911 Targa. It was 100xxx miles, and condition is fair. However, I found the positions of the pedals very peculiar (for someone who knows nothing about air cooled 911s). The gas pedal is very recessed from the brake, and the brake travel is very small. Plus there is very little space to the right of the gas pedal, so it's impossible for me to do heel and toe. Is this usual for 911s in this and earlier periods? Is there any improvement for the 964 Turbo? FYI, I have a gen 1 Cayman S and the pedals are just perfect for me. |
You just aren't used to it. And yes, the brake pedal height can be adjusted. Also note, these pedals are "floor mounted" and don't hang from above like your Cayman, so they seem to travel a bit differently.
Also consider, if you are tracking the car, and the brakes get hot, the pedal will be lower, which will assist in your heal/toe. Also consider the fact that some "heal toe" can be 1) heal on brake, toe on gas 2) toe on brake, heal on gas 3) rolling the foot.. left side on brake, right side on gas Or, you could spend $$$$ on fancy, shiny pedal "pads" that purport to make it easier. But not every car you drive has these pedals, so learning and practicing on a variation of pedal placements will make you more adept the next time. |
who knows, never been in a 964 but your 911 sounds about right. I hear the 964 turbo is a pretty rare beast
Originally Posted by racer
(Post 9105428)
You just aren't used to it...
Or, you could spend $$$$ on fancy, shiny pedal "pads" that purport to make it easier There are many opinions and options out there, but this worked for me. |
Originally Posted by Carrera3.2LG50
(Post 9106216)
I have an '87 and I never did get used to it, so I decided to spend some $$$$ on fancy pedal pads (mine aren't shiny) and an adjustable throttle pad to raise up the gas pedal to be closer to the brake. Got 'em from Rennline and I am very happy with the resulting ability to more easily heel/toe.
Hi Paul, Thanks for the info. Could you post a pic of what your pedals look like? |
Originally Posted by Reiver
(Post 9107534)
Yes, you can heel and toe a 911. I end up turning my foot about 45 degree CCW.
Originally Posted by Caferacer
(Post 9107754)
This doesn't work for me due to the height diffeential. Maybe I need Ronald McDonald shoes.
Originally Posted by Ed Hughes
(Post 9107992)
Had to do the same in mine. Took about an hour of driving to get use to it but then felt fine. |
Originally Posted by gti2kids
(Post 9106306)
Hi Paul,
Thanks for the info. Could you post a pic of what your pedals look like? https://rennlist.com/forums/911-foru...-this-car.html |
Having the brake pedal higher actually helps you to just blip the gas while really crushing down on the brake...
(Post 9108639)
I responded to another post regarding heel/toe earlier this year and posted some pics in Post #15 in this thread:
https://rennlist.com/forums/911-foru...-this-car.html Thanks for the photos. It seems your brake and gas pedals are almost flush. Does this mean that the gas is actually higher when you fully depress the brake? |
(Post 9111371)
Hi Paul,
Originally Posted by KILRWAIL
(Post 9108076)
You can raise the accelerator pedal and lower the brake using the standard adjustable pushrods, allowing the brake to be slightly above the accelerator when fully depressed.
