How to check engine wear ?
RL Technical Advisor
Vifa,
The only real way to determine engine wear is by disassembly and inspection/measurement.
One can perform leakdown tests which give a snapshot of potential valve and/or ring problems, however that tells nothing about pistons, bearings, timing chains, sprockets, and other internal wear parts.
So even with a good leakdown test the pistons and bearings could be in a bad shape ?
What about cylinder wear ?
Sorry for all the questions, but I have a lot to learn when it comes to engines.
