82 targa rough running help!
I have noticed a small what I think is a mis at low rpm say in second or third gear when I apply the throttle lately, otherwise, the car starts and has been running great. Yesterday when starting my car for the ride home, after running fine to work, it started, but was very rough, missing, popping, low idle almost dying! I could pump the throttle and it would run ok (didn't sound like on all cylinders) at about 3k rpm - enough for my short drive home. I removed all the plugs and cleaned them, they looked ok. What is wrong??
You can be having fueling issues. I am working on an issue were I believe my car will lean out or miss sporadically after about an hour of driving but can sometimes be stopped by shutting off the car and restarting after a few minutes. This is an electrical issue for me. You should take a look at your cap and rotor if you don't know how long it has been there. Check your fuel pump relay and fuel pressure.
