911 Forum 1964-1989
Finally Starting my 3.2 to 3.4 Conversion
Old 02-06-2010, 10:04 AM
  #46
theiceman
Team Owner
theiceman's Avatar
Received 1,015 Likes on 722 Posts
wow I think I am getting a hard on
so how did you get the case and engine parts so clean ? that looks amazing ... so do you have to keep track of which cylinder and head goes where ? I imagine there has to be some type of "leveling" involved so when you put the cam tower on there is no high spots or gaps... ?
looks totally awesome .. great job so far..
Old 02-06-2010, 10:28 AM
  #47
Dentron
Dentron's Avatar
Basically a razor blade for gaskets, glue and dried seals, Cleaning Solvent, wire-brush a cleaning tank and lots of patience and time.
Old 02-06-2010, 11:57 AM
  #48
Ed Hughes
Ed Hughes's Avatar
That is why you have to be careful to keep the cylinder group heights the same or compensate if you machine or replace one. I would assume the same would be required if you ever replaced a head. Clean surfaces on the heads and cam tower mating surfaces with no nicks or gouges, then a thin even coat of sealant. Other than that, there is no shimming or leveling.
Old 02-06-2010, 12:10 PM
  #49
Ed Hughes
Ed Hughes's Avatar
Originally Posted by Dentron
Ed, I'm a rookie at this. When you rebuilt your engine what all did you have done?
I never answered this...only the question on the honing, which you entirely ignored!
Case checked for bore, etc
Crank inspected, micropolished
Rods rebushed-resized
ARP Rod Bolts
Supertec Headstuds
New Rings
Cylinders machined to compensate for some taper
Aasco Racing Valve Springs/Ti Retainers
Rebuilt Heads-new exhaust valves (no choice there!) and twin-plug machined
Cams reground to DC19 profile, refurb rockers by DRC
New rocker hardware, RSR seals
Timing chains, ramps
New crank sensors
New fuel lines
New Bosch alternator
Injectors inspected/cleaned
Powder coat on tin, Ceramic coating on shroud and fan, valve covers
Oil cooler tested (pinhole repaired) and cleaned (HIGHLY recommended!)
Flywheel, clutch and pressure plate were fairly new, and reused with new flywheel bolts.
And now, she gets the finishing touches.
BTW, yours looks great. I found the assembly part to be quite rewarding-I hope you're having a good time!
Old 02-06-2010, 02:42 PM
  #50
Dentron
Dentron's Avatar
Nope I didn't ignore it. I spoke with Steve Wong at 911 Chips and, we discussed it, and we're going to Dyno the car after the break in. There is additional horsepower to be gained, but no I never ignored what you said. We're just weighing all options and opinions as we work through this. My guys (Aase Motors) are helping me build my motor, and I am considering any and all ideas from others and everything is being considered. I wish I could take credit for all of it, but Jeff and Alan have a good grasp moving through the project and have been very good helping me toss ideas... The assembly is fun (with my limited role) I'm playing a role with the entire project, but I have to keep doing my day job. I'm better at that than building motors. Maybe the next one I will do end to end alone.
Steve Wong, and I, along with my guys at Aase will dial this in on the Dyno when we're done. It's a street car that I'm just having fun with.
You know the guys at Aase Motors?
This is an Aase Motor build... I just make the suggestions, help, learn and pay the bills.
I'm still a rookie on complete end to end rebuilds. I don't trust myself.
Without our little family it wouldn't look this clean.
ARP Rod Bolts
Supertec Headstuds
New Rings
New crank sensors
New fuel lines
Old 02-06-2010, 02:49 PM
  #51
Ed Hughes
Ed Hughes's Avatar
Just ribbing you about the extruding.
Old 02-06-2010, 03:00 PM
  #52
Dentron
Dentron's Avatar
I know Ed... I looked at the dual plug idea, but I'll pass on that one. We were discussing that one and maybe next build.
You're a good resource Ed... It helped me turn a couple corners as far as decisions along the way.
Thanks for the Help...
C.L.
Old 02-06-2010, 04:13 PM
  #53
Ed Hughes
Ed Hughes's Avatar
I don't know Aase, but they certainly have a good name.
Old 02-08-2010, 06:21 PM
  #54
Dentron
Dentron's Avatar
The Conversion moves on.
We just had the Heads Beveled to accommodate the 3.4 Cylinders.
Old 02-08-2010, 08:04 PM
  #55
Ed Hughes
Ed Hughes's Avatar
Dentron: Can you resize your pics? The width makes it tough to view without a bunch of scrolling.
Is Aase doing the machining? If not, who is?
Old 02-08-2010, 09:01 PM
  #56
Amber Gramps
Amber Gramps's Avatar
Dentron, are you in Fontana?
Old 02-08-2010, 10:38 PM
  #57
Dentron
Dentron's Avatar
Where is Fontana...? We're not from there.
Old 02-08-2010, 10:45 PM
  #58
Amber Gramps
Sorry, it's in the Inland Empire. I was having flashback's thinking you may be someone else. Carry on.
Old 02-08-2010, 10:46 PM
  #59
Dentron
Dentron's Avatar
Ed Aase does their won machine work.
Old 02-08-2010, 10:47 PM
  #60
rusnak
I haddah Google dat
rusnak's Avatar
hoo wee...nice pics. I'm looking at the bevel and the piston crown, back at the bevel, again at piston crown....etc
Quick Reply: Finally Starting my 3.2 to 3.4 Conversion
