Psycho Porsche-any else's do this???
About 5 weeks ago I started my 911 to take my son for ice cream and the car stunk of gas and sure enough there were drips coming from the fuel pump area. Started the car the next day sure enough the problem "corrected itself". Due to work/weather/etc. hadn't started the car for 2-3 weeks and yesterday it leaked again. Left the car out overnight, jacked it up, removed the fuel pump cover, and was ready to see where it was leaking from and sure enough the leak fixed itself(?!)....bone dry and car was running fine....WTF?
Gas evaporated, that is why you did not see anything.
Trying running the car with the stone guard removed for a few minutes and then use a paper towel around the fuel pump fitting to see if any fuel residue seeped out.
Try it outside if you gave a gas water heater in the garage.
I had the same situation and replaced the banjo sealing washers and end cap.
John
John
I don't know how many times I have read about something like this only to end up as a catastrophy. Your car is warning you....look for the leak don't ignore it. Recently I had a small radiator fluid leak on my 3.0CSI BMW. I thought I fixed it by making the clamp tighter. Next morning still with a little leak...went to work and finaly the leaky hose gave way.
It was PIA to repair this in the office with little tools....I should have done a better job looking for that cracked hose.
abe
abe
