Weltmeister Sway Bar Adjustment
I bought an '88 Carerra two years ago and use it for DE track events. I want to adjust the Weltmeister sway bars that came with the car, but with no installation instructions.
If I want to soften the front sway bar and decrease understeer so I move the clamp rearward on the car? Do I adjust the drop link at the same time? Does anyone have a PDF of the installation instructions? Thanks |
Mike,
To reduce understeer, loosen the front swaybar clamp and slide it forward toward the end of the bar. You will need to adjust the droplinks to remove the preload, too. |
Hi,
question, how do you adjust the front sway bar with no pre-load? do I leabe the wheel on? I can barley get at it witht he wheel on. I loosened the front bars off, drove arounf the block to reset the suspension and I notive the drop links were pushed forward to the end of the bar....the only way I can adjust the bar stiffer is if I remove the wheel, then it will move easily...sorry if this is a dumb question...thanks for any help. |
