Left camshaft oil line 85 Carrera
I have an 85 Carrera engine. My left camshaft oil line is dripping when the engine is running (drips at the junction to the left of the hose section).
Vertex has this as a Porsche Cam Oil Line Left Camshaft Carrera for $25.00 and part #93010734704.
Has anyone replaced this part and what do I need to do? This is the 2nd time I had to replace this (about 5 yrs ago). (I also posted this message as a reply to the Post: 1989 911 Cam oil line, but decide to post new since my engine is different and I am concerned I might have something else to do or watch out for when replacing this.
Ummmm if this is the second time you've done it........, I assume a shop did it for you the first time? Take care of it asap before oil starts leaking on your hot cat = fire, ask me how I know..... If I remember correctly you'll have to remove the distributor to get to the case-side nut, the rest is straight forward. Be careful with the tensioner line, use 2 wrenches. While you're at it check the otherside too.
Thanks for the post.
I had a very reputable shop replace it last time, so I would be surprised if that were the problem. What causes them to fail, esp. at that junction? Vibration? Hard driving? Heat?
I wonder if it matters more WHERE you get the part. Is there a difference btwn factry or OEM part (does Porsche even make these themselves)? Do all online and retail stores have the same oil lines?
I had my top and bottom end done on my car and drove it up to Ohio. On the way driving it back down to Georgia, I notice smoke coming off my left heat exchanger. When I checked the engine compartment I notice oil leaking from the left cam oil line. I used some liquid weld at the banjo fitting until I got the car back to my mechanic.
My mechanic stated that it was the left cam oil line and the problem is those lines are remanufacture that are sold with the updated Carrera chain tensioner kits. The only part that is OEM supposely is the chain tensioner cover. He charged me $34.00 for the left cam oil line part, no labor to put it on. Pelican has the part for $22.50.
I haddah Google dat
just order the cam line. If you can change a tire then you can be talked through it on Rennlist. If you want to install it at home and get stuck, I'm sure many here will help you out.
Team Owner
a couple of basic tips .
Get an OE line if possible from Porsche
get new crush washers for the banjo fitting and other fitings as nesesary
do NOT over torque the banjo fitting as it can break easily.
This is a must-new crush washers and ferrells, otherwise you'll just have leaks in a different spot!
When I changed this line on my 85 a few years ago, I discovered they changed the design slightly - they moved the middle tap about 1" on the updated/replacement line. It worked, but had to bend the other line to meet the new location.
Either bad parts or a screwy copy, IMO. I've changed both of mine in the last two years, and they matched perfectly....
Team Owner
it looks like the replacement one is just to short ... looks like the left side would overlay perectly .. are you sure your ordering the right part? just wonderin
