What is this plug?
What is this plug?
I don't remember taping this off and can't figure out what it might have gone too. It looks like the connector going to the speed control. It comes out of the harness with the WUR, blower motor connector and rear engine harness connector.
Pete,
Where would the other end be? This wire could reach to the driver's side fuse block, maybe to the firewall, and barely above the CIS. I can't find the other end anywhere.
What's coming out of the upper, left corner of your engine compartment (above the stock position for the engine lid support)? Most of the cars use a 2-stage defroster, with red/blk, red/wht & brown (grnd) wires, and use a connector like that. If that wire was tied to the alternator harness, under the left side intake runners, it also could be a "not-used" connector...
Just an outsider looking in here...It looks too dirty to have been pulled on. It has an untouched look to it. No grease, no smudges, and the dust hasn't even been nocked off of it. It had that muddy look to it like you never touched it before. the prongs don't even look like they have been bent recently.
I was thinking about this one, while Stevie was writing. I do believe it's unused in the SC application, but used on Turbo engines (not sure if that year car shared the engine harness with the Turbo - no USA Turbos that year). This is one of those, "Darn, I've seen that connector five hundred times, but..." moments.
It is under the left side intake runners and had tape over it. I guess I'll go with the not used theory, cuz I don't see anything. My friend has an 84 euro 930 i could check.
I have a Thermo Time switch, but it has different connectors.
Thanks all for the help.
