Varioram help req!
Varioram help req!
Does anyone know how to setup a stand alone fuel system (electromotive tec3r) to run a Varioram intake system. I just picked one up and have no idea where to start! I used the tec3 with the 95 standard black ABS intake that has a single switch to open the botton tube and had no problem with that but I have no idea about the Varioram. Also if I could see what the plumbing looks like and vacuum tube routing was that might be a start. I'm sure someone out there knows I just need that persons help...
Addicted Specialist
I don't fully understand your question, but by "varioram" are you referring to 96-98 993s? If so, you may want to try posting on the 993 board.
Edward
Edward
