915 clutch pedal travel…
I have a 1985 cab, not quite 80K miles. Clutch works fine, but it feels like I have to let the pedal out further than I used to for it to engage. Not a lot more, but enough to notice. How much travel should there be before the clutch engages? Is the additonal pedal travel indicative of wear? Is there an adjustment I should make?
Thanks!
Thanks!
The further out it bites, the sooner you will need to replace it. Always a tell on a clutch that is at the end of it's life.
This is a pretty simple procedure that you should try first:
Porsche 911 Clutch Adjustment | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
