911 Forum 1964-1989
911 SC wheel fitment question...
Old 06-14-2019, 04:32 PM
mpiffaretti
mpiffaretti's Avatar
Default 911 SC wheel fitment question...
I have a 911 SC body, with a recent 3.6 964 conversion, which produces way too much torque for my 15 x 7 and 8 inch Fuchs.
I have recently found a set of decently priced BBS RS 16 inch with the intent of increasing diamater and have more tire options.
The set has the following specs:
9x16 ET 11 REARS
8X16 ET 28 FRONTS
Per my research seems that the fronts would fit by adding a 12 mm spacer (to bring offset to +15), but I'm not sure about the rears.. I do have some camber, and the fenders are rolled, but I still dont know if they would fit or not.
Can anybody chime in if the above offsets would fit and what tire sizes?
Old 06-14-2019, 09:24 PM
Bill Verburg
Bill Verburg's Avatar
9x16 ET 11 REARS
8X16 ET 28 FRONTS
Spacers can only lower the ET never raise it.
8X16 ET 28 FRONTS is a good fit in front the recommended range for an 8 is ET25 to 30, tire would be a 225/50 or 225/45
9x16 ET11 is a bit aggressive in back and close to the edge but a 245/45 ought to work
a much more efficient way to go is
BFG G-force Rival S 1.5
8x15ET27 225/45
9.5x15 ET19 245/40
You'd have to have some custom o/s 15s made
Old 06-14-2019, 11:12 PM
mpiffaretti
Thanks Steve, I was hoping you would chime in!
would love to keep 15’s but tire options are limited plus im trying to increase diameter while retaining period correct looks... a lot of conpromises
Old 06-15-2019, 11:29 AM
Bill Verburg
Steve????
Any time you increase the diameter of the tire or the weight of the assembly it will sap performance, In the extreme 5--60 lb-ft. Diameter increase is the worst in this regard, additionally diameter has a major effect on fitment. Of course there is aplay between diameter, width and offset.
as a for instance the BBS wheels 9ET11 may be doable w/ a 245/45x16 but less so w/ a slightly taller 225/50x16 and impossible w/ a 255/50x16 all because of tire height
A 255/40x17 on a 9ET15 or 9.5ET19 would fit fine, because of the wheel Et and lower tire diameter.
Old 06-17-2019, 10:15 AM
mpiffaretti
Default thank you!!
Thanks BIll!!! sorry buddy didnt meant to call you steve! LOL.
And yes, I am aware that a larger diameter will sap performance, but with 310 WHP on a such a light car (on 15 fuchs with a 40 profiled tire) my first gear just cooks the rear tires at WOT.
I appreciate your feedback on tire sizes, you have no idea how much hassle and headaches you just saved me!
Martin
Old 06-18-2019, 10:32 AM
Bill Verburg
4
Martin
I understand your thinking, I went through a similar process when I did my first 3.6 t/p. The main reason to go to a taller tire is to get more reasonable cruise rpms. But it's still a balancing act, you don't wan to go too far. I went from 7 & 8x15 to 7 & 9x16 to 8 & 9.5 x17, rears were 225/50 to 245/45 to 275/40 to 255/40.
I'd highly recommend 17 just because of tire choices, w/ 8 & 9 215/45 & 245/40 or 225/45 & 255/40 is a pretty good compromise
Old 06-22-2019, 02:45 PM
racerbvd
racerbvd's Avatar
I have a set of 8&9X16 BBS rims that I use on my 88 Carrera . Just had to roll the front fender lips
Old 06-26-2019, 05:40 PM
sithot
sithot's Avatar
Here are 8" & 9" Ruf Speedline wheels. Ruf recommends 215/235. These wheels are running 225/265 which fit but it's close. If used they'll probably get 225/245. Tire choices dictate this.
Old 06-26-2019, 06:37 PM
sithot
sithot's Avatar
"Rear" 265/17 x 9" and a 225/16 x 8" The Ruf 8's and 9's work great on SC's and Carreras.
Old 06-26-2019, 07:01 PM
Bill Verburg
The early Ruf Speedlines pictured are 8 ET30.4 & 9 ET17.7,(both have ETs that are on the side of caution placing the wheel/tire assembly a few mm more inboard than usual) tires would be 225/45 & 255/40 or 215/45 & 245/40 x17 for most usual driving situations
Here you can see the fitment boxes for an SC/Carrera, In the box works, the closer to the edge the more potential issues will need to be adressed
Old 06-27-2019, 09:06 AM
sithot
sithot's Avatar
Thanks for the chart, Bill. Sort of like the 7R wheels which were backspaced to fit the body. The Ruf wheel was on a 930 and the 265 was no issue. On an SC it's a little close for comfort; I have not run them much and went back to my stock 7 and 8 Fuchs setup with what may have been the "last" sets of RE11 Bridgestones.. When I decide on tires I'll make the switch.
Best,
Tom
Old 06-29-2019, 03:05 AM
racerbvd
racerbvd's Avatar
I have a set on my 81 SC that I am building.
Quick Reply: 911 SC wheel fitment question...
