911 3.2 rear brake caliper question
Renewing my brakes and just wanted to ask how people are setting the proper torque on the rear caliper bolts. There is no way I can get a socket in there for the bottom bolt. I used the 5lb hammer + 19mm spanner to crack those mugs. Do you just tighten them as much as you can and hope for the best?
thanks in advance!
thanks in advance!
