911 Forum 1964-1989
Driver side miiror on 1988 Carerra
Old 08-21-2018, 07:37 PM
Dwight Johnson
Dwight Johnson's Avatar
Default Driver side miiror on 1988 Carerra
The glass of the mirror falls out of the frame. I tried to gently/firmly push it back into the housing and it stays for a bit and then falls out again. The wiring is still attached and prevents the glass mirror from falling out complete. It hangs by the wiring. Any advice how to get the mirror glass to stay in the housing?
Thanks,
Dwight
Old 08-22-2018, 09:08 AM
AG81
AG81's Avatar
New Mirror or New Mirror or Glue.
Old 08-22-2018, 12:11 PM
76FJ55
76FJ55's Avatar
If your mirror looks like the one pictured by AG81, there should be a hole in the bottom center of the mirror housing that you stick a small flat blade up into to rotate the retaining ring which captures the ears he has identified with the red arrows.
Old 08-22-2018, 01:56 PM
AG81
AG81's Avatar
76FJ55.....Thank you.
I got a call and did not elaborate prior to posting.........
Old 08-23-2018, 01:51 PM
Dwight Johnson
Default Mirror issue
The picture is exactly my mirror. So after I psuh the mirror pegs back into the holes I should inset something to rotate the housing and that will secure the mirror?
Thanks,
Dwight
Old 08-23-2018, 03:17 PM
76FJ55
76FJ55's Avatar
This may help.
https://www.youtube.com/watch?v=xWXeaSB9-l8
Quick Reply: Driver side miiror on 1988 Carerra
