Oil pressure relief valve - Rennlist - Porsche Discussion Forums
911 Forum
Old 07-11-2018, 04:18 AM
floatss
User
floatss's Avatar
Default Oil pressure relief valve
Hi Gents,
Are the oil pressure relief valve adjustable. My 911SC oil press is a bit low.
Regards
Chris
floatss is online now
Old 07-11-2018, 08:52 AM
theiceman
Super User
theiceman's Avatar
As far as I know its determined by the spring for bypass so none adjustable.
What do you mean by a " bit low"
theiceman is offline
Old 07-11-2018, 09:47 AM
floatss
User
floatss's Avatar
TKS Iceman,
The oil press needle had been jumpie for quite some time before I cleaned the terminal of the sencor. I now get a nice steady indication, however on cold start pressure does not peg the needle at the top of the guage and at warm idle the needle drops very low. Not zero but very low.
Unfortunately, I am in the UK at present and do not remember the gauge increments. Going from memory and expressing it in percentages I recall that cold start press would indicate about 80% and warm Idle about 5% with a steady needle. It is a 1983 911 SC with 270,000 km.
Regards
Chris
Old 07-11-2018, 10:35 AM
theiceman
Super User
theiceman's Avatar
Chris i have very similar milage. " pegging " the needle only happens in cooler temps for me if i remember but i will recheck. If its warm out in start ( ambient not engine temp) car dies not kick into high idle so keep that on mind too. Currently we are at about 28c here.
What viscosity are you running ?
Also at idle fully warned up some cars even flicker the light. Mine does not . But i have heard this is not unusual
Old 07-11-2018, 11:11 AM
floatss
User
floatss's Avatar
TKS Iceman,
Unfortunately I don’t know what grade oil was put in during the last service. I took her to our Porsche guy in Cape Town for service and brake pads and fluid change, etc. I only fixed the oil press contact afterwards, so never asked him. I’ll find out when home in about three weeks time.
My high idle kicks in like clock work. However during warm ambient conditions, like 28 plus, it will settle down quite quickly as it should, and yes, I also get low oil press and alternator flicker at times.
My E Type has the same low pressure indication and I was advised to shim the pressure relief valve, which I will attempt when back home. I was hoping that a similar simple fix would be possible with the Porsche as well.
Much appreciated.
Regards
Chris
Old 07-11-2018, 12:47 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
I hope your shop didn't put 0w-40 or 5w-40 oil in there since thats trouble.
These engines need high ZDDP oils in either 15w-40, 15w-50 or a 20w-50 oil.
You should have 10psi per thousand RPM.
Steve Weiner-Rennsport Systems is offline
Old 07-11-2018, 01:12 PM
floatss
User
floatss's Avatar
TKS Steve,
I am quite sure it would be 20w-50, which is what I use to top up, but I’ll check when I get home.
IIRC it idles at about 8 psi and goes up to about 30 @ 3000rpm.
Regards
Chris
Old 07-11-2018, 01:40 PM
Mark Salvetti
Mark Salvetti's Avatar
That actually sounds about right. Sometimes the low oil pressure light will even flicker at idle. You could consider installing the restrictors on the cam oil lines to increase oil pressure slightly, at the expense of some oil flow to the cams (part number 901.105.361.02). I've seen mixed opinions on the wisdom of using these, though.
Steve, do you use the restrictors in these engines?
Mark
Mark Salvetti is offline
Old 07-11-2018, 10:25 PM
Mark
No effing way.
Reducing oil flow to the hottest parts of the engine (heads, cams, valve springs) is completely and totally counter-intuitive to me.
With proper bearing clearances, good oil, and the proper oil pump in good condition, they are not needed.
Old 07-11-2018, 10:46 PM
sithot
sithot's Avatar
^ What he said both posts.
sithot is offline
Old 07-12-2018, 06:58 AM
floatss
User
floatss's Avatar
Thanks Gents, much appreciated.
Chris
Contact Us Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
