Wheel nuts stuck on.
This is the second time removing tires/rims since owning the car last fall and the wheel nuts are stuck on. It has the stock Fuchs and nuts. Is that a common issue with daily driven in all weathers cars?
Should I put some anti-seize on it?
Team Owner
Lol absolutely.
I use copper anti seize.
I only go to 90lbs torque and it works well.
How tight are you torquing your wheels ?
I think the spec is 95lbs dry.
Officially, I believe Porsche discourages the use of anti-seize on wheel studs.
I have a different opinion on the use of anti-seize. I have used anti-seize on the wheel studs of all my 911's Fuchs for many years. I apply a small amount on each stud; it will usually last a couple of years unless you remove your wheels frequently.
Based on the situation you have with your wheel nuts, I would suggest using anti-seize going forward. I would also recommend you check the torque setting when installing wheel nuts. I torque the lug nuts on my Fuchs to 95 ft. lbs. (130 nm).
Good luck.
Good luck.
RL Technical Advisor
FWIW,...
NEVER use anti-seize on the threads; apply a thin coat on the shoulders of the lug nuts.
Make sure your torque wrench is accurate by having it tested. Torque to 92-94 lbs-ft.
Done.
Done.
Porsche has a TSB about how to use anti-seize on the wheel studs/nuts. If you cannot break them loose they can be cut off with careful use of a hole saw, etc.
New ones will look nice until you torque them and mess up the anodizing
It was at a tire shop and they ended up having to "drill out" 2.......what a mess.
Second for antiseize In the rust prone Northeast with no issues. The Antiseize can act as a lubricant so dial in your torque wrench to the lower end of spec. Recheck after 100 miles or so.
