911 Forum 1964-1989
ATE brake fluid
Old 02-22-2018, 02:32 PM
bcgreen
bcgreen's Avatar
Default ATE brake fluid
I am in the process to do a brake flush and my last container of ATE is a Super Blue Racing DOT 4. Searching the internet I notice there are other ATE DOT4 brake fluids such as Amber, SL,and 200. Will any of these ATE I mentioned work?
Do I have to stick with ATE, can I go with Pentosin Super DOT4.
My last question is I need a small rubber hose to attach the brake caliper nipple for the bleed. What size and where would I purchase the hose?
Old 02-22-2018, 04:26 PM
Bill Verburg
Bill Verburg's Avatar
Any DoT 4 can be used
here are some DoT 4 wet/dry boiling points in F
Castrol SRF 518/608 highest wet BP
Endless RF650 424/622
Motul RBF 600 401/594
ATE Super Blue 396/536
ATE 200 388/536 most common Euro factory fill
Pentosin Super DoT4 356/500
ATE SL.6 338/509
ATE SL 329/500
Old 02-22-2018, 04:29 PM
177mph
177mph's Avatar
And ATE super blue is no longer blue. FYI.
Old 02-22-2018, 05:34 PM
wildcat077
wildcat077's Avatar
People used to flush the blue and fill with amber and vice versa, guess you knew when all the fluid was changed ...
For what it's worth , i used the ATE brake fluid in my 911 for extensive track days and never had issues, now i use Motul in the race car
but the ATE will be fine for everyday use !
Old 02-22-2018, 07:14 PM
r911
Anti-Cupholder League
r911's Avatar
real issue is whether this older brake fluid is in a sealed can or not?
if it was opened I'd buy new and use that
Yes, all brake fluid in the US is now amber - apparently a severe moron infestation caused sufficient problems that brake fluid must now be a single color
Old 02-23-2018, 10:55 AM
raspritz
raspritz's Avatar
When the ban on ATE SuperBlue in the USA was announced, I bought a big stock of it for my racecar. I still do alternate flushes, ATE Superblue and Motul RBF600. Blue-yellow.
Old 02-23-2018, 11:38 AM
Dave Inc.
Dave Inc.'s Avatar
The motul RBF600 has specs that say it's a much better product but does anyone feel a big difference? I went from the ATE to the Motul for my last track day and really couldn't tell. Maybe...maybe the Motul held up a little better but I'm probably just imagining that.
Old 02-23-2018, 11:53 AM
177mph
177mph's Avatar
Brake fluid choices "can" be subjective. There are certainly numbers available to compare products. However - Ive used ATE on track for years without a single failure or overheating issue. My .02
Old 02-23-2018, 01:25 PM
bcgreen
bcgreen's Avatar
I am not doing track days with this particular Carrera, but I do like to be able to purchase a DOT4 that is a different colour than what's in there presently, as this tells me when all the old fluid is out.
Old 02-26-2018, 05:41 PM
Dave Inc.
Dave Inc.'s Avatar
They're all amber now by law. Not much to be done about that one.
Old 02-26-2018, 09:20 PM
bcgreen
bcgreen's Avatar
Works for me because my fluid is clear.
Old 03-01-2018, 01:10 PM
Cory M
Cory M's Avatar
ATE 200 is the same as ATE Blue except for the color
Quick Reply: ATE brake fluid
