Lexan Margard windows for streeet longhood?
My 71 has almost all the glass scratched up. I would like to take 50lb off it but keep stock appearance, by installing 5-6mm double hardened, anti fog and rain-x coated Margard lexan.
My main concern is noise and scratching. I use it for mountainous road trips and occasional track days. How much more noise is there with Lexan?
Scratching: the hardened Margard or Markrolon is stil about 3.3X less scratch resistant than glass. But it’s a lot lighter. Maybe put in on rear and quarters only, so wipers and rolling windows are against glass?
thoughts and experience?
I wouldn't run Lexan or polycarbonate windows on the street, they get beat up and scratch easily. I've got them on my racecar, have to use a special spray to wipe them clean because Windex messes them up. I also think your weight savings estimates may be optimistic.
R windshield glass with defrost strips on a '73 is 16 lbs. - dunno the wt. of the polycarbonate
- in LA, JAck Olsen has something like that on his mainly track, some street, car
the newer 'vettes come stock with a light plastic windshield with some coating on it, so it is possible
it IS in back & up high so something to do after FG R. bumpers, etc.
Just read on a build thread that doing all of the the side glass saved 35 pounds, more than I thought. So maybe you could leave the front glass and still hit your 50 pound goal.
*Edit: that weight savings also included swapping out the regulators for R style straps
crank up windows + hinged R windows on both sides will come to about 20 lbs., so that 35 lbs. must also include the rear glass backlight
50 is not possible from substituting Lexan for glass unless you do the windshield too
If I can remove 400#'s from a cabriolet and still have a car comfortable enough to take my wife on 2,000 mile road trips than do we really need to replace the windshield? I'm of the camp that says it stays.
Oh noise......LOL..... Try felt carpet in a cabrio. You can talk before and after but not during the driving. Add in the Bisimoto pipe and it no wonder I don't wear my hearing aids.
Oh, and Bilstein, Poway did the custom valving rebuilds on the dampers.
