Flares on the 74 Carrera - is this duck OEM?
https://www.ebay.com/itm/1974-Porsch...dYrI7i&vxp=mtr
I'm trying to figure out if this is all OEM (apart from the engine swap). What do the eyes of the experts spot with this guy?
RL Technical Advisor
Without seeing it for myself, I cannot testify about its originality, however I can tell you that its VIN is a genuine US Carrera. The owner added the power mirrors (never available in '74) and VPC A/C which is dealer-installed air conditioning. Flares & ducktail were standard for these cars.
I've owned one of these cars for 42 years.
This car has been for sale for over a year- probably the 3rd or 4th time I have seen it on ebay. Typically bidding tops out @ the 38k range.
If I remember correctly - the the underneath doesn't look so hot ( rust)
Chances for head stud issues are real. '74 through '89 cars must prove they are in good shape. The last 2 SC's I've owned had them done due to failure.
The aluminum-cased engines OTOH, do not pull the threads out of the case; these have the Gen 1 Dilavars which were prone to failure due to corrosion. Thankfully, the Gen 2 Dilavars (993TT) do not suffer the same fate and are the preferred solution for the 3.0-4.0 engines.
