SupremePower Akrapovic OPF/GPF link pipe GROUP BUY
#691
Yes. (If I understand your question correctly)
I didn't have to remove or even loosen the muffler section to get the link pipes out.
Drivers side ALL of the studs came out of the cat -- so removal was really easy.
Passenger side ONE of the studs came out (so two remained) -- and there was enough give to allow me to get the link pipe out.
If you're asking about the muffler section removal .. no idea. I didn't remove it.
I didn't remove it because I have no clue how to remove the line that controls the PSE valve and it seems like it would be easy for me to break.
I never had a problem with any of the nuts or studs everything came off cleanly and no studs moved at all.
Yes, I left all studs in place, when I did the rear section the OEM came back 'just' far enough with the studs in place to get it down and out, sure it would have been easier with the studs out but it is not necessary. The OAP was even easier, with the rear exhaust out they slipped out without any interference.
#693
I also assembled my QJ and then did this install.
TIP! Orient the QJ backwards from now they depict in the manual. Send the hoses forward to the motor unit. Put the motor unit in front of the car. Then there won't be anything in the way.
I had it the normal way initially and the hoses would have been in the way right where I was rolling around.
#697
Right now it is back on the JCR rear section, temporarily secured with a twist of 14ga copper wire, I will be fashioning a more appropriate clamp from stainless steel tube when time permits.
Last edited by Westcoast; 03-16-2021 at 02:28 PM. Reason: correct the removal procedure
#698
#699
The vacuum line (if that what we are talking about here) can be carefully pulled off 'once' you use side cutters to remove the crimp clamp at the valve end, you may be able to slid it off without doing this but I didn't try. FWIW, the JCR valve has a larger diameter nipple than the OEM, I had to massage the inner lining of the vacuum line in order to get it on.
#700
#701
#702
(Oetiker ear clamps)
#703
Here is a picture of the OEM clamps and the tool I used to pry them off, the JCR valve nipples being bigger required me to open up the line at that end, the OEM clamps as they came off would not go back on, hence the copper twist wire.
Old school trim removal tool
OEM clamps at exhaust valves
#704
OK, I need to back up just a little, I edited my original post, I did NOT have to cut them, I found a trim removal tool that I could get behind the hose end with and lever it off as there is no raised end on the nipple.
#705
Already google is returning many more options!
