Remove Spyder 3rd Brake Light Lens?
Received 3,460 Likes
Anyone know how to do it?
@JAhmed did it , I found that thread (looks like you posted in it too), so maybe PM him
https://rennlist.com/forums/718-gts-...re-buying.html
I saw that but I am talking about just the red lens since I want to wrap it, which will be easier to do off the car.
Gotcha… I have NOT done this, but I’m pretty sure it would go like this:
If you lift the lid you’ll see the rubber grommets that cover the access holes.
Push them in and pop out to see the access (screws/bolts/nuts?) and then undue them. I would tape the light down so it doesn’t fall out while you un-assemble it.
Unplug the electric connector and carefully remove.
It MIGHT be double face taped, like the Sirius wart pic was in the above thread I posted, but I don’t think so since the light bar mounts on 2 sides.
once it’s removed, you should be able to figure out how to disassemble it. If not, post a pic in this thread.
Good Luck
Good Luck
