718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Gear 1-2 grind
Old 07-31-2022, 06:38 PM
  #976
RoadrunnerGTS
RoadrunnerGTS's Avatar
Received 1,123 Likes on 558 Posts
Originally Posted by AdamIsAdam
FYI, today I shifted very slowly into a gear with ARM switched on. I let the RPM's drop way below where they would need to be for the next upshifted gear. The car did not auto-blip on the upshift. I read above someone commenting about that functionality and I didn't think my car did that so I checked. I doesn't.
It does ARM on upshift, but apparently only within a certain time frame. If you hold the clutch in for perhaps more than 2 seconds, then it won't ARM on upshift. I often notice it most on 2nd to 3rd, although it is subtle vs downshift ARM.
Old 07-31-2022, 07:25 PM
  #977
AdamIsAdam
AdamIsAdam's Avatar
Received 4,075 Likes on 1,769 Posts
I guess I shift too prefect to notice. 😉
Actually I'll check it next time I'm out.
Old 07-31-2022, 07:42 PM
  #978
85Gold
85Gold's Avatar
What's this ARM you speak of.
Peter
Old 07-31-2022, 08:43 PM
  #979
RoadrunnerGTS
I have only noticed it in casual driving around town from 1st to 2nd, and 2nd to 3rd. My guess is it aims to make for a smoother upshift.
Info here:
Post 8 & 9: https://www.planet-9.com/threads/rev...gimmic.100210/
https://rennlist.com/forums/718-gts-...2-upshift.html
Old 07-31-2022, 08:54 PM
  #980
UncleDude
UncleDude's Avatar
Received 5,535 Likes on 2,264 Posts
Info here:
Just tried in mine, could not detect any throttle being added in shifts 1-2 or 2-3.
Old 07-31-2022, 09:33 PM
  #981
RoadrunnerGTS
Mine only does it sometimes in certain scenarios. I will try to isolate what those are. From memory it is a slow change from 3500 in typical casual city driving from 2nd to 3rd that I have noticed it most. It is easy to miss as it is subtle. It is more obvious with VC and valves open.
Old 07-31-2022, 09:49 PM
  #982
TXshaggy
TXshaggy's Avatar
Received 3,903 Likes on 2,207 Posts
Just spitballing here, but if you spend enough time in the 3/4 neutral gate your “upshift” is the same as an auto blip downshift.
The GT4/Spyder OM specifically states auto blip is a “downshift” feature.
Old 07-31-2022, 11:18 PM
  #983
RoadrunnerGTS
Agree what the OM says, but I find Porsche OM's are lacking information for the most part when requiring more detailed information.
From research I did, ARM is simply attempting to match the target gear, it doesnt care what gear you are coming from, up or down. Example, 5th to 3rd down or 2nd to 3rd up, key is to match required revs for 3rd. That said, with 718 long ratios, it would be odd for it to need to ARM on an upshift as revs would typically be above target still.
Porsche basically copied Nissan's ARM in the 370Z, and that Nissan states SRM/ARM is used on all gear changes, up or down. Here is info on Nissan's SRM (ARM) https://www.caranddriver.com/feature...tch-explained/
I know that the BMW M2 does rev matching up or down.
It would be great if there was more info available on this. I'd also like to know how DeMan maintains ARM when changing the ratios and not updating any of the software.
Old 07-31-2022, 11:59 PM
  #984
TXshaggy
TXshaggy's Avatar
The article you linked essentially repeated what I said. If you delay long enough it’s an auto blip up. Had the same in my Z06.
Old 08-01-2022, 01:32 AM
  #985
bob78h
bob78h's Avatar
Was ARM switched on?
I usually drive with rev match on.
I guess the problem is, the grinding happens so rarely and randomly that it's hard to know whether ARM is the cause or not. For me, it at least seems unrelated to shifting speed or revs. I've had it happen shifting quickly and shifting slowly. And for sure I have the clutch all the way down, so I hope operator error isn't a factor.
Old 08-01-2022, 10:47 AM
  #986
Westcoast
Westcoast's Avatar
Received 4,766 Likes on 2,764 Posts
Peter
Automatic Rev Matching
Old 08-01-2022, 10:48 AM
  #987
Westcoast
Westcoast's Avatar
It has be reported that Auto Blip remains in play with a DeMan gearset installed.
Old 08-01-2022, 11:26 AM
  #988
85Gold
85Gold's Avatar
You mean like Heel and Toe.
Peter
Old 08-01-2022, 11:45 AM
  #989
Westcoast
Westcoast's Avatar
Peter
If that is you and your car pictured in the lead then you probably don't need ARM... and prefer heel and toe!
Old 08-01-2022, 12:29 PM
  #990
85Gold
85Gold's Avatar
It is funny to me about all the Purists who want a manual transmission experience and then the 1st thing they do is turn on ARM. Not saying 2nd gear grind isn't real. I had it on one of my 6GT3 when the tranny was cold. Cold trans fluid and speed shifting can beat the synchros on most cars.
Peter
Westcoast (08-01-2022)
Quick Reply: Gear 1-2 grind
