718 Brake fluid flush
I need to flush/replace brake fluid prior to a track weekend, as I did many times over the years when tracking my '83 911 and then a 2002 996 C4S. However, the owners manual for my 2019 Cayman GTS says "don't try this at home." Any idea why? Has anyone done a brake fluid flush on a 718? I hate to think what the dealer would charge! Thanks for any thoughts/advice. (And apologies if this has already been addressed; I couldn't find any postings on it.)
I did a flush on my 718 and it was really no different than doing it on my 993. Biggest PIA was dealing with the lug bolts instead of studs, which I have since converted.
Welcome to the forum.
Somewhat surprisingly our local dealer is quite reasonable on the brake fluid renewal. Nonetheless it is a straightforward job on the 982 as part of track day preparations. Porsche wheel R&R hardware makes fitting easier than many marques. https://cimg4.ibsrv.net/gimg/rennlis...b769150de6.jpg https://cimg3.ibsrv.net/gimg/rennlis...e5388ee495.jpg https://cimg9.ibsrv.net/gimg/rennlis...cf74f33eeb.jpg https://cimg0.ibsrv.net/gimg/rennlis...12583dfb4f.jpg |
I did my GTS also. Nothing different than other cars.
Originally Posted by splinterAMG
(Post 16037764)
Somewhat surprisingly our local dealer is quite reasonable on the brake fluid renewal. Nonetheless it is a straightforward job on the 982 as part of track day preparations. Porsche wheel R&R hardware makes fitting easier than many marques. I'd like to do this for my 991.2 (coming up on 2 years), and eventually my 718. Dealer 6+ hour round trip, so I've done oil changes and would like to add brake flush, pads when needed. |
You need a bottle and tube to collect the fluid. You can do it one wheel at a time, just takes longer. The R&R tool is to make it easier to reinstall the wheel. Here is one from amazon.
splinterAMG can you give some insight as to the procedure you used to get your car up on four jack stands? Where did place your jack?
Thanks to all responders. And Splinter, thanks for the great photos of a beautiful Boxster (and PCCBs)! I too wonder what your jacking technique is to get all four feet off the ground. And Greg, thanks for the link to the R&R tool. I'd fabricated one when I had my 996, but gave it to the new owner.
Originally Posted by Greg Fishman
(Post 16039306)
You need a bottle and tube to collect the fluid. You can do it one wheel at a time, just takes longer. The R&R tool is to make it easier to reinstall the wheel. Here is one from amazon. https://www.amazon.com/ABN-Piece-Han...omotive&sr=1-3
Thanks |
I do mine with 1.0 L total, with Endless RBF650
For those interested here are some of the top tier brake fluids as reported on Build Journal https://cimg3.ibsrv.net/gimg/rennlis...3d35239906.png |
Originally Posted by InTgr8r
(Post 16414372)
Originally Posted by dhc3
(Post 16040261)
https://cimg3.ibsrv.net/gimg/rennlis...80d475bac5.jpg If you get a Quick Jack, it makes life a lot easier! https://cimg7.ibsrv.net/gimg/rennlis...b4ce1a642d.jpg |
Thanks guys, appreciate the knowledge!
Originally Posted by X2Board
(Post 16414545)
My process is to jack the passenger rear high enough to place the front passenger stand, lower the car, repeat on the driver's side, then jack from the rear center of the car for the rear stands.
Originally Posted by asuptardorne
(Post 16416647)
Where can you safely jack from the rear center of the car?
http://www.jackpointjackstands.com/ |
