Sound deadening in 2018 718 Boxster
Has anyone experimented with sound deadening material in these cars? The engine is so close to the driver's ears, and I find the noise annoying. There might be room to put panels of such material on the firewall or elsewhere.
Thanx!
Thanx!
You might try deactivating the Soundaktor. The change is subtle (in my opinion) but...
The easiest means I've read yet (and what I did) was:
1) In the trunk, right side rear, just by the tail light: pull the liner back to get a view of the fuse panel behind.
2) Pull the fuse to this device: 7.5A fuse (red) in row A (top), slot 10 (last).
Easily reversed if you don't like the change.
