New member introduction and new GTS boxter build help
Definitely go sit in both. I'm a slim guy, athletic build and 5'11". Just as you assumed, I was all signed up for the sport plus 18 way. Just after my order was placed, I had an opportunity to sit in both for a bit and immediately called to change to the regular sport seats (14 way). Just liked them better. Don't assume based on your reading... too expensive an option to guess at.
1) My initial plan was to buy boxter S and not GTS , but then for alacantara seats i switched it to GTS.
But after watching Nick Murrey's video on youtube I changed my mind, Personally i have never touched alacantara. I would visit porsche dealer this weekend and check it out.
2) Yes , My preference for Color is black, and the black GTS trims won't contrast. I want to stick to black color atleast
3) Comming back to the main point , GTS vs S, I tried the same configuration for S in configurator (turned out to be ~95$K) I can save 5K here , But if i choose to opt GTS i would keep the alacantara.
I am mostly inclined towards GTS more than S.
4) What is "model designation"? I am sorry if it sounds a stupid question.
Thanks you in advance
So on to the alcantara... if you want alcantara, then you absolutely want to go with the GTS; however, in your build list you selected leather seats, which automatically selects "deletion of Alcantara"; I bolded/italicized/underlined for clarity:
Here is my Primary build ,
Model 2019 718 Boxster GTS
Jet Black Metallic
Roadster Top in Black
Standard Interior in Black i.c.w. Leather Sport Seats Plus
Premium Package i.c.w. Adaptive Sport Seats Plus (18-way)
"Automatically Dimming Mirrors with
Integrated Rain Sensor"
2-Zone Automatic Climate Control
Seat Heating
7-speed Porsche Doppelkupplung (PDK)
Power Steering Plus
20" Carrera S Wheels
Adaptive Cruise Control (ACC)
Lane Change Assist (LCA)
Steering Wheel in Leather
Deletion of Alcantara®
Adaptive Sport Seats Plus (18-way) with Memory Package
Seat Belts in Racing Yellow
Voice Control i.c.w. Navigation including Porsche Connect
BOSE® Surround Sound System
Apple CarPlay™
Navigation including Porsche Connect $
So this makes me think the configurator has misled you a bit, especially since you seem to want to keep the Alcantara. I dug around a bit more in the configurator. If you want to keep Alcantara with the same options, it comes out to $98,630 (http://www.porsche-code.com/PKX4CFX7 )- which is about $2000 less than if you chose to switch to leather seats. This still doesn't include the GTS interior package, which adds a full leather dash and contrast stitching, and a few other things but is VERY expensive (I think $5k more because you have to get the leather package for the dash).
Same options, but with an S, including the performance options included as standard in a GTS AND leather seats (PTV, SC, PASM, black carrera s wheels), comes to $96,620 (http://www.porsche-code.com/PKXNQFU9). Still cheaper, but close enough to justify the jump up to a GTS, especially if you want Alcantara.
TL;DR, make sure you thoroughly evaluate what interior you want, especially the seats, because it's a couple thousand dollars difference and it's where you'll be spending all your time in the car! If you don't just HAVE TO HAVE the 18-way seats, then settle for the 2-way and save yourself over $3000.
A couple more things, just suggestions so take them however you want:
- I honestly never use the navigation in my car. I always use the Waze app on my phone. I've found the traffic and route predictions are just better than what comes in the car, even with an active Sirius subscription. A solid phone mount that you can stick in one of the vents can be had for $30; if you use your phone for navigation now consider nixing the $2300 Nav package.
- Unless you already are used to a car with Adaptive Cruise Control AND frequently take long trips, consider nixing that option and saving yourself $1700.
The Porsche options game is fun, isn't it?
Thank you rddustang, I would contact dealers this weekend.
I am focusing on finalizing my build right now.
Getting a delivery in late sep or early October would be an issue for me as it will start snow here in michigan. I also need recommendation for tires. Does default tires good for winter?
That said, I live in a climate with all four seasons (DC metro), and I drove on my summer tires all winter. I did NOT drive in snow/ice, but I did drive in cold. I avoided extreme cold (the car basically stayed parked all January when temps hovered between 5 and 15 degrees F), but I didn't notice any significant traction loss in temps ~20-30 degrees F. I also didn't drive like an idiot, for what it's worth. The weather will flip flop in my area so frequently that it really makes no sense to swap tires constantly, or run into situations where it's 70 degrees in February and you're on Winter tires. I have the luxury of choosing not to drive my car when it's extremely cold or snowing, so I opted not to swap out tires and suffered no ill effects. That's my .02, I'm sure someone will come right behind me and suggest that you absolutely have to have winter tires if you drive below 50 degrees F.
I would still go and sit in them. I would start by seeing if you like the sports seats or the sports seats plus. Then determine if you are OK with manually adjusted seats or power adjusted. The difference isn't just power but the number of ways the seats adjust. The 2-way adjust 6 ways (2 power and 4 manually) and the 14 or 18 way seats adjust in more directions including lumbar support.
Personally I like the sports seats and LOVE the sports plus seats. The power adjustment isn't all the big of a deal to me but I am adding it to my build.
1) Exterior color , Jet black/blue or carmine red(added price )
2) Alacantara or leather ( interior ,steering wheel and seats)
3) Seats ( sport or sports plus 2/14/18 ways )
4) navigation system ( buy or not ) whether apple car play is sufficient for navigation.
based on the feedback I am going to finalize following things on my first Porsche dealer visit.
Peter
I won't be tracking either, just commuting to work and driving through twisty mountain roads at unsafe speeds. So for me, it was ventilated leather 14-way seats. As much as I've complained about how the options jack the price of these cars through the roof, crikey the customization is fun.
Interesting take on the seat situation for large or smaller people.
For what its worth, I am 5'10" 235lbs, not athletic at all and have no problems with fitting comfortably into my LWB's for 4+ hours of driving.
Like has been said above, you need to sit in them while driving.
Test drove boxter S today , this was my first time driving a sports car
i was finding difficulty getting inside the car lol
Car felt too powerful to me , steering wheel is so responsive and smooth
My first visit experience :
I called dealership and scheduled an appointment.
i met the sales guy and talked with him regarding my interest in 2019 boxter GTS model
he didn’t have any GTS boxter models for test drive but he had an S model
I sat in all 14 way and 18 way sports plus seats
and I am opting for 18 ways seats sports plus
Driving position is too low which I am not used to.
i also got to see alcantara interior in one of the cayenne
overalll I loved the car , and I would opt for boxter jet black
he also said that apple car play would be sufficient and no need to buy navigation
Total price of the car was 102,130 and even without asking for discount he gave me 4% discount
which made the price down to 98,030 but after adding sales tax and documentation Fee the total became 104,182.84
should I ask for more discount ?
As for discount it depends on the size of the dealership. If he offered you 4% without asking then I'm guessing it's a decent size dealer and you could probably get 6-7%.
Maybe consider the base car. If you've never driven a sports car before the GTS is almost surely overkill; the base model is actually faster than the previous gen S (and maybe even GTS...).
Some people have complained about turbo lag but I didn't get that when I drove a base Cayman for a few days as a loaner a couple weeks ago. That will surely knock the price down and you could buy a LOADED base Boxster for ~$75k.
This time I enjoyed the drive so much
may be I was nervous the first time , test driving such an expensive car lol
Based on the feedback , I have my configuration ready
718 Boxster GTS 2019
Exterior Color
Black
Interior Color
Leather/Alcantara® Interior in Black/Carmine Red i.c.w. GTS Interior Package
Packages
Automatically Dimming Mirrors with Integrated Rain Sensor
Seat Heating
Performance
Power Steering Plus
PASM Sport Suspension (Lowered 20 mm)
Smoking Package
Luggage Net in Passenger Footwell
Apple CarPlay™
Total Price*
$102,370
Any feedback is appreciated
I went to different dealer to test drive cayman GTS and boxter S
Exterior Color
Black
Interior Color
Packages
Seat Heating
Performance
Power Steering Plus
Smoking Package
Apple CarPlay™
Total Price*
$102,370
Next step after you get the car and break it in, I strongly recommend to get out to an autocross and/or HPDE. The car will transform again once you start getting more familiar with it and be even more enjoyable, if you can imagine that.
That's actually awesome, almost seemed like you were underwhelmed when you first drove it. So you basically upgraded to the GTS interior package and the sport suspension... honestly that's the way to go with these cars IMO, and I think the red contrast stitching is going to look amazing with the black exterior. It's a great spec sheet! Pretty much exactly how I'd spec it, except I'd go manual.and skip the navigation (I'd prob get carmine red too but blacked out is always a good look). Went the opposite direction with the price but hopefully you get a good discount- and at the end of the day, life is short. Get what you want; when you're already spending this much money I guess it doesn't make too much sense to compromise for a grand or two. In fact you'll probably appreciate the car more and the money will feel better spent; assuming you're not stretching your budget.
I learned driving on manual cars ,from past 3 years I have been driving automatic.
Considering fuel consumption and I really liked the pdk transmission I am going with PDK
I saw the dashboard with non interior package which looked cheap
so decided to upgrade to interior package
Hello Guys,
I am planning to add Heated Multi function Steering wheel 480$ option
How good is it with alacantara steering wheel which i am planning to opt?
Thank you
Thank you
