356 Forum 1948-1965
'58 356A coupe...
Old 07-21-2017, 10:57 PM
Peter Zimmermann
Peter Zimmermann's Avatar
Originally Posted by zoomie50
45 ft/lbs 50 Maximum. If engine in car E brake on and car in 4th gear. Your choice to hold if engine out of car.
Engine is out, and on a stand. It is easy for me to install a "holder" on the flywheel in order to torque the pulley bolt. Where on earth did you find the spec? BTW; THANK YOU!
Old 07-21-2017, 11:03 PM
Peter Zimmermann
Originally Posted by jcnesq
LOL. I guess my buddy who owned it was trying to fool some people, but not me. He wanted $2,400 for it.
In 1971 I sold my '58, black plate, rust free, CA since new, Speedster, serial # 84811, with S90 power for $3500. I bought my first house with the money.
Old 07-24-2017, 05:29 PM
Peter Zimmermann
Please, anyone & zoomie, where was the torque spec listed for my crank pulley bolt?
Old 07-24-2017, 05:45 PM
sithot
sithot's Avatar
"Tighten till it gets loose and back off 1/4 turn." - redneck engineering
Personally, I'd use these numbers:
https://porsche356registry.org/article/100
Old 07-24-2017, 06:47 PM
Peter Zimmermann
Uh, nothing listed for "crankshaft pulley bolt..." only thread size.
Old 07-24-2017, 07:14 PM
zoomie50
zoomie50's Avatar
356 registry link: http://forum.porsche356registry.org/...ft+pulley+bolt
Old 07-24-2017, 08:36 PM
Peter Zimmermann
Thanks, zoomie! I had a hunch it didn't appear anywhere (???), but now I wonder if using a thread sealer will call for a different torque amount. I think that I'll use 50 lb/ft, and apply a super-thin layer of the old standby; Curil T, to both the threads and under the lock washer. BTW; the pulley bolt was so darn tight that I had to put a bar on the flywheel, and use a 2' long breaker bar with a 4' long piece of galvanized pipe to loosen it. I'm happy that the crankshaft didn't break!
Old 08-01-2017, 05:16 PM
Peter Zimmermann
Ta-da! Harness is out. Only have a couple morning hours to work before my garage is over 95F, but the old wires, including the positive battery to starter cable (not pictured) are on the floor.
Old 08-01-2017, 10:27 PM
jcnesq
Miserable Old Bastard
jcnesq's Avatar
For crankshaft pully bolt torque, several guys who are pros responded with 45# in this Registry thread: http://forum.porsche356registry.org/...hp?f=1&t=34150
Old 08-02-2017, 03:25 AM
Peter Zimmermann
Thanks, Jim! I'll be installing the pulley tomorrow, along with anything else I can get done as the temp in my garage slowly climbs to the century mark - again!
Old 08-03-2017, 12:32 AM
Peter Zimmermann
Kinda funny! One of the posters in that thread gave flywheel torque as "350 ft-lbs +". Well, I hate to bring this up, but my factory manual states flywheel gland nut/hollow bolt, torque as 250 - 267 ft-lbs. Just a little difference! BTW; only the S 90 & SC flywheels had a higher gland nut torque spec; listed in the factory Spec Book as 325 - 361 ft-lbs. The Spec Book lists the torque for all engines as 253 - 271 ft-lbs, but in a separate listing shows the S 90 & SC specs. Just sayin'.
Old 08-16-2017, 02:14 PM
Peter Zimmermann
Progress. Engine not intended to be a show winner, just sweet. Harness going in (red arrow are fuse box connections). Whew!
Quick Reply: '58 356A coupe...
