Capacitive Discharge System (CDI)
I just bought a pair of Winterburns for my 356 Carrera - working on installing them now and will be able to report on them in a couple of weeks. Fred says they will fire a hot spark at anything over 3 volts. He builds them personally in small batches on a design patented by his father in the 1960's updated with more modern components. I corresponded with him via email for two months prior to my purchase and I was pretty impressed with his knowledge. He even bench tested a setup we discussed to fire two coils of one set of points so the plugs would fire at the same time (a problem with the dual ignition setup on 4-cams).
http://www.capacitordischargeignition.com/
Permatune used to make a 6 Volt CDI but used units are hard to find and expensive. I think 123 distributors in England can provide a six volt set up.
Since I was doing a period correct restoration trying to duplicate the way my car appeared in all of the magazines in the late 1950's I had to go with real old school Lucas 6 volt headlights - Tri-Y in the top and Flamethrowers in the bottom as installed by Dean Jeffries. Not the greatest light output but since my car is more of a show car at this point its what I did. I'm not sure if there is a 6 Volt LED option but I would certainly research that for a daily driver.
