Wheel and Tire Forum
Will Front OEM Wheels Fit Rear of 991.1 (for snows)?
Old 12-24-2016, 06:16 AM
gar777
gar777's Avatar
Default Will Front OEM Wheels Fit Rear of 991.1 (for snows)?
I'm looking to create an effective winter wheel\tire setup for my 2014 991.
20x11" wheels with 305/30R20 tires sure look sexy -- and are great for dry traction -- but are not ideal for winter\snow traction.
On prior cars (BMWs), I replaced the staggered wheel setup for a square set up by using 4 front wheels when mounting snows because this: (1) gave me a narrower wheel\tire = better snow traction and (2) allowed me to use the same tire sizes at all 4 corners, which allowed 4-corner rotation (when tires weren't directional)
I'd like to see if I could use a square winter set up on my 2014 911, using the front OEM wheels = 19x8.5" (or aftermarket wheels in similar width and offset) on all 4 corners with tires in size 225/45R19 (~27" tall) or 235/40R19 (~26.4" tall).
Using www.willtheyfit.com - it seems like the fronts would fit the rear wheel opening, although they'd stick out ~0.5" less than the stock rears and I'd lose ~2" of the width from the inner side. I think this will look OK (not the sexiest but OK for winter). I'd also lose the tire diameter differential (OEM rears are ~0.6" taller than fronts) but I think this would probably be OK for lower speed\less aero winter driving.
Anyone do this before?
What do you think?
Old 12-29-2016, 07:59 AM
Slantnose!
Slantnose!'s Avatar
No...I haven't done or seen this set-up, probably wouldn't do it whether it technically fits or not.
Old 01-03-2017, 06:46 PM
brad@tirerack.com
Former Vendor
brad@tirerack.com's Avatar
Older Boxsters yes, but I have never put the same size all the way around on a 911. Even if they fit, I'd be concerned the dry performance would be thrown off quite a bit by having a tire 2+" skinnier back there. There's also close to a thousand pounds of load capacity difference between the front and rear sized tires. That's not a good idea on a rear engine car.
Could you do it? Probably, as long as you had sufficient load capacity for it to be safe. But, I suspect it would handle terribly. Unless you added adapters (25+mm) it would also look ridiculous.
Quick Reply: Will Front OEM Wheels Fit Rear of 991.1 (for snows)?
