Wheel/Tire Fitment Confirmation
Hey guys/gals, I'm considering purchasing aftermarket wheels/tires for my 2001 996TT.
From the preliminary research I've done on the forum thus far, I know that the OEM sizes are as follows:
Fronts: 18x8 +50 with 225/40/18 tires
Rears: 18x11 +45 with 295/35/18 tires
I'm in need of assistance in confirming whether or not the following aftermarket set will fit:
Aftermarket specs currently being considered:
Fronts: 19x8.5 +50 with 235/35/19 tires
Rears: 19x11.5 +60 with 305/30/19 tires
According to: http://www.willtheyfit.com/
The new proposed fronts:
Compared to your existing wheel, this new wheel will have an inner rim which is 6.3mm closer to the suspension strut. The outer rim will poke out 6.3mm more than before.
The new proposed rears:
Compared to your existing wheel, this new wheel will have an inner rim which is 21.4mm closer to the suspension strut. The outer rim will poke out 8.7mm less than before.
Looks like the fronts will fit just fine, but the rears will need spacers in order to clear the inside wheel well and/or the suspension? Would a 10mm spacer in the rear be enough?
the aftermarket specs for the rear wheels are for narrow body fitment.
IMO, you're better off looking for a rear offset a lot closer to stock, aka, a widebody fitment.
19 X11 et +40, 19X11.5 et +45, 19X12 et +50 .
Spacers will make it work, but I'm not a big fan of using them to make a NB wheel fit a WB car.
Former Vendor
996 setups we've done
BLACK FRIDAY DEALS STARTING TODAY!
UP TO 50% DISCOUNTS ON SPECIFIC SETUPS.
BRAND NEW IN STOCK INVENTORY Listed at bottom of thread
All RTF wheels are custom manufactured using aerospace grade 6061-T6 forged aluminum per order.
This allows us an advantage in being able to offer any offset, width and finish when you order any of our RTF Track Spec or Modular Series.
Available sizes
18x8, 18x8.5, 18x9, 18x9.5, 18x10, 18x10.5, 18x11, 18x11.5, 18x12, **18x13**
19x8, 19x8.5, 19x9, 19x9.5, 19x10, 19x10.5, 19x11, 19x12, **19x13**
20x8, 20x8.5, 20x9, 20x9.5, 20x10, 20x10.5, 20x11, 20x12
21x8, 21x8.5, 21x9, 21x9.5, 21x10, 21x10.5, 21x11, 21x11.5, 21x12, **21x13**
** Limited availability **
Specifications
* 3pc Forged Concave MonoBloc Contruction.
* RTF MonoBloc Series wheels are manufactured using 6061-T6 aerospace-grade forged aluminum for maximum strength-to-weight ratio.
* Special pocketing is standard to minimize unsprung mass and rotational inertia for maximum performance and handling.
* CNC machined to all custom specifications.
** Centerlock applications available. **
* Bead seat knurling available on all Track Spec Series wheels.
* PTP weight reduction ( Stage 1) applicable.
* CTP weight reduction (Stage 2) applicable.
* CTP.v2 weight reduction (Stage 3) applicable.
* Machined to clear all Big Brake Kits applications.
* OEM TPMS compatible.
* 2 Year finish warranty.
* Limited lifetime structural warranty.
Profiles do vary based on car and fitment
Available sizes
Specifications
If you have any questions on any of our designs please feel free to send us an email directly to Sales@RTFWheels.com or a PM.
RTF is currently offer media discounts on 3 of our new MonoBloc Series designs.
Track Spec-M10, Track Spec-10 * CTP Edition *, Track Spec-5 *CTP.v2 Edition*
and our all new RTF Track Spec-Spyder
Media discount available to limited Porsche chassis.
RTF Track Spec-5
Size: 18 x 8 / 18 x 11
Finish: Satin Black w/ PCCB Yellow Pinstripe
Car: 996 Turbo S
RTF Track Spec-5
Car: 996 Turbo S
RTF Track Spec-5
Size: 18x8.5 F / 18x11 R
Finish: RTF Brush Titanium
Car: 996 Turbo
RTF Track Spec-5
Car: 996 Turbo
