Wheel and Tire Forum
BBS E88 Assembly - DIY Instructions
Old 05-24-2013, 09:56 AM
tedean
tedean's Avatar
Originally Posted by V
Hmm. BBS recommends not to do this but to use the gasket only. You need to check the bolt TQ after a few heat cycles though and tighten if neccessary. Replacing parts of a wheel which has silicone in between can be quite messy, I suppose that's why they don't like it.
Gosh, I pulled the wheel apart, verified the gasket was new, cleaned everything. Nothing appeared bent or nicked, retorqued and still had a leak. The wheel must have been damaged? Only then did I apply the silicone in desperation. Agree it will be a mess next time if I take it apart.
Old 05-25-2013, 06:55 AM
chsu74
chsu74's Avatar
Originally Posted by zweebach
I have purchased used rims from Bob Woodman Tires (bobwoodmantires.com) and also directly from BBS America. Both offer great service; I have no offiliation with either.
Thanks!
Old 05-25-2013, 09:48 AM
Peter Carroll/Toronto
Peter Carroll/Toronto's Avatar
Wasn't a big deal for me. I used a razor blade to slice the silicone and separate the halves. Then used the razor to remove most from the halves. Reassembly was not a big deal.
I've had a lot of trouble over the years with 3pc rims leaking. If you miss a leak and run flat, you can do a lot of damage. The extra reliability is well worth a little rebuild hassle.
Old 06-02-2013, 11:13 PM
chsu74
chsu74's Avatar
What RTV silicone is recommended? Loctite 37460?
http://www.toolup.com/loctite_37460_...Fcye4AodlFIAnw
Old 06-03-2013, 09:09 AM
I don't think it really matters as long as it can handle higher temperatures... You're just trying to seal air leaking on something hot... If the BBS parts do their job, it doesn't do anything. It's just a little insurance.
You'll need a few tubes. Probably 3... You don't put it between the halves. It has to be metal to metal for the bolted halves. You use it to fill the crack around the joint after the wheel is built. Make a substantial bead.
Old 07-12-2013, 05:47 PM
deactivateduser66
deactivateduser66's Avatar
Great post, thank you!
Old 08-11-2013, 11:10 PM
chsu74
chsu74's Avatar
Metal valve stem gasket source? Buy new set or replace the gasket. I took mine apart and the gasket looks difficult to replace. Where does everyone source their valve stems?
Spyerx (10-16-2020)
Old 08-12-2013, 12:00 AM
Call Bob Woodman Tires. They stock them. Not expensive... Best source for BBS parts.
http://www.bobwoodmantires.com/
Old 08-13-2013, 11:18 AM
chsu74
chsu74's Avatar
Thanks. Will reach out to BBS America and Bob for quotes
Old 08-14-2013, 10:23 PM
chsu74
chsu74's Avatar
Cathy from Bob Woodman got back to me and is fantastic. She helped me with my setup and discovered that the previous owner swapped the centers from front to rear by mistake. I knew that I had the right rims but something was off. She saved me a ton of money. Can't say enough good things about them.
Old 09-12-2013, 03:58 AM
V
V's Avatar
Hey guys, any recommendation on a torque wrench for assembly? NM or Lb/Ft doesn't matter. Should be with 3/8 shaft.
Old 09-15-2013, 09:29 PM
rlme36
rlme36's Avatar
I purchase precision instruments. They supply or use to supply snapon. For wheels you'll need a really low amount of torque setting, I think the 3/8's drive will work int ft lbs. or you. An get their in lbs version.
Old 09-16-2013, 07:06 AM
V
V's Avatar
Cool, like thisone;
http://www.toolsource.com/precision-...8-p-94538.html
no affil
Old 09-16-2013, 09:46 AM
rlme36
rlme36's Avatar
Yes. The split beam is the best iteration of torque wrenches. Use it all the time for my track car no issues still calibrated to spec.
Old 09-17-2013, 05:50 PM
V
V's Avatar
Ordered it now. Does anyone know if you can actually buy just the rubber O-ring from BBS without having to buy the entire metal ring every time..?
Quick Reply: BBS E88 Assembly - DIY Instructions
