Vendor Announcements A place for Rennlist Sponsors to post new products, sales, and deals for members.
Presenting the AWE Tuning Porsche 991.2 Carrera SwitchPath™ Exhaust. Available now.
Old 03-16-2017, 04:38 PM
Josh/AWE
Basic Sponsor
Josh/AWE's Avatar
Arrow Presenting the AWE Tuning Porsche 991.2 Carrera SwitchPath™ Exhaust. Available now.
Spool up with SwitchPath™. Presenting the AWE Tuning 991.2 PSE SwitchPath™ Exhaust:
  • Max gains of 11 hp and 7 ft-lbs of torque at the crank (Carrera S)
  • Max gains of 14 hp and 17 ft-lbs of torque at the crank (Carrera base)
  • Featuring an X-pipe and true balance pipe
  • Retains factory PSE operation
  • Exhaust flow is continuously routed through integrated X-pipe, delivering a constant exotic tone regardless of valve position
  • Factory-matched valved and non-valved inlets
  • No muffler packing means the tone will not change over time
  • Fits S and base PSE Carreras
  • Less is more: clean, straight-through design maximizing flow and performance
  • 102mm double-walled tips available in chrome silver or diamond black
  • Engineered, designed, and manufactured in-house at AWE Tuning
  • Handcrafted from U.S.-sourced CNC mandrel-bent 0.065” wall T304L stainless steel
  • Precision TIG-welded
  • Direct bolt-on for factory-like simplicity
  • Perfect fitment - guaranteed
  • AWE Tuning No Check Engine Light Guarantee
  • Featuring the AWE Tuning Lifetime Warranty
The Options
SwitchPath™ Exhaust
Our most intricately-designed Porsche application to date, the AWE Tuning SwitchPath™ Exhaust for PSE-equipped 991.2 Carreras provides the perfect sophisticated soundtrack fit for the .2.
Comprised of an integrated x-pipe, balance tube, factory-matched valved and non-valved inlets, and two straight-through mufflers designed specifically for Porsche’s new turbo-powered Carrera, the SwitchPath™ Exhaust proves to be the all-around solution while retaining factory PSE operation.
SwitchPath™ magic
The SwitchPath™ Exhaust will respond to your driving style. Around town cruising is sophisticated and refined. Thanks to the 0.65” wall T304L stainless steel, and the integrated x-pipe and balance bar, the SwitchPath™ Exhaust provides a consistent, deep and refined exotic tone, even with the valves closed.
Once the ECU registers an elevated RPM and opens the valves, the tone produced from the SwitchPath™ ratchets up, increased turbo sound and feedback from downshifts included. And due to there being zero acoustical packing material within the mufflers, the soundtrack emitted from the SwitchPath™ Exhaust will not change over time.
Spool on.
Tip Options:
All tip options include the AWE Tuning logo, and double walling to ensure a mirror finish even under hard usage. All tips are individually adjustable, allowing depth into the bumper to be set according to personal taste.
  • 102mm slash-cut diamond black tips
  • 102mm slash-cut chrome silver tips
What’s in the box?
Complete AWE Tuning SwitchPath™ Exhaust, two exhaust tips in desired finish, and all required installation hardware.
Data:
You’ve got questions? We’ve got answers. 1.888.565.2257, 215.658.1670 or performance@AWE-Tuning.com.
Josh Davis > Performance Specialist
AWE-Tuning.com > 1.888.565.2257
my email > facebook > twitter > instagram > youtube
Josh/AWE is offline
Quick Reply: Presenting the AWE Tuning Porsche 991.2 Carrera SwitchPath™ Exhaust. Available now.
