Mark this thread as Unsold
928 S4 5 speed 1989 Black on Black
Year: 1989
Make: Porsche
Model: 928
Cont. Porsche Models: 928 (all)
Mileage (numbers only please): 153000
Options (Please check ALL which apply): Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Blacl
VIN: WP0JB0924KS860137
Price (no $ sign please): $16000
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Florida car
Ebay listing with more details:
http://www.ebay.com/itm/131118148396...84.m1558.l2649
Option codes:
158 Radio Blaupunkt Reno SQR46 (gone)
220 Locking Differential (LSD)
383 Sport Seat Left, electrical vertically adjustable
387 Sport Seat Right, electrical vertically adjustable
418 Side protection Moldings
481 Manual Transmission
570 Air Conditioner with improved efficiency
650 Electrical Sliding Sunroof
Radio and Amplifier installed by previous owner:
Pioneer DEHP735
Amplifier EQX Series II
Up to date maintenance and service
The Good - Mechanical updates and Maintenance with less than 3,000 miles ago (most really recently). Have all invoices and documentation from big three.
- Replaced Timing Belt and Water Pump, Roller and Tensioner (will need to be checked for adjustment soon)
- New Radiator Hoses, Accessory Belts, Thermostat.
- Replaced Water Coolant Pressure Switch and Coolant Level Sensor
- Coolant drained and replaced with Zerex G-05
- Starter / Alternator wiring replaced
- Changed Engine Oil (Mobil 1 15W-50 with 1,300 ppm Zinc level) and Oil Filter
- New Hatch Struts
- New Window Switch, Rear Wiper Switch
- Replaced Power Steering Supply, High Pressure and Return Hoses and Reservoir. Drained Steering fluid and replaced with new.
- Replaced Passenger Dash Air Vent
- Replaced 4-way Vacuum Connector (located by Brake Booster), Vacuum actuators (Foot well and center comb flap) diaphragms and Vacuum solenoid. Had A/C professionally vacuumed and recharged
- Replaced Heater Valve and Short Hose
- New Driver's side Door Striker
- Performed full Intake Refresh, replacing among others: Vacuum Lines, Knock Sensors, Crank Position Sensor, ISV, seals and gaskets, Fuel Lines, Oil Dipstick, MAF Rubber Cowl and Y Connection, Fuel Injector Seal Kit (did not have them tested). Powder coated Intake Manifold and Cam Covers (color: Tin Foil Silver P-7103B from Prismatic Powders). Renewed Fuel Rail and Fuel Cooler insulation. Tested Throttle position sensor and vacuum after refresh
- Removed steel collar from Windshield Washer Reservoir and replaced Fill Tube Lid
- New original "928 S4" Rear Decal light grey
- New Aluminum Fuel Vent Y Connector at passenger side wheel well
- New Bosch Battery
- New Pedal Pads
- Installed Console Support Bracket from Jaeger Engineering
- Replaced Air Filter
- New B Pillar Speakers - Alpine Co-Axial
- New Roger 928 RUs Engine Mounts
- Replaced Oil Pan Gasket and installed Studs Set.
- Flushed Clutch Actuator when installing Oil Pan Gasket
- Installed Reman Steering Rack
- Wheels Alignment
- New Hatch Release Receiver
- Replaced both Fan Motors by used ones
- New Shifter Rear Coupler bushings
- Fuel Filter replaced
- Replaced Horn with two new FIAMM
- Replaced Windshield glass
- Removed front Tow Plug and re-tapped thread
Additional new parts that will go with the car:
Cam Plugs (hockey pucks), Hatch Rubber Buffers, Front Brake Pad Sensors Wires and Rear Seat Belt Rose. Used Driver's Side Door Wiring from 928 International
The Bad - Known Issues:
- Central Lock not working. I suspect I have a broken wire at the Driver's Door (see that the car will go with a used wiring to have this fixed)
- Rear Hatch Motor cycles but does not open from the inside (cracked lock). Opens with key
- Scratches Front and Rear Bumpers
- Corrosion points on Rear Quarter Windows
- Driver's Side Interior Quarter Panel distorted due to exposure to sun and needs to be refurbished.
- No Front Engine Belly Guard (it does have the Rear Belly Guard)
- Front Spoiler cracked
PPIs welcome
Thanks in advance
