Anyone using a diesel fuel additive?
Old 02-17-2017, 11:43 AM
ned911
ned911's Avatar
Default Anyone using a diesel fuel additive?
My '04 duramax died on me due to algae in the fuel tank (she's back up and running).
Anyone using an additive to help with this issue? If so what?
This is a common problem with diesels.
Old 02-17-2017, 12:59 PM
jwasilko
jwasilko's Avatar
I haven't needed it, but http://powerservice.com/psp_product/...-fuel-biocide/ would be my go-to if I did.
Old 02-18-2017, 08:44 PM
Matt55
Matt55's Avatar
I have used this before, works great with water and algae http://www.ezoil.com/documents/Diese...et%20Email.pdf
Old 02-23-2017, 04:41 PM
Hoyt
Hoyt's Avatar
Never needed it for algae. I guess I go thru too much of it for it to get funky.
Now, I do use this in every tank during the winter season here in Michigan. My truck seems to start a little easier and I don't have to worry about gelling of the fuel.
http://stanadyneadditives.com/performance-formula/
Old 02-27-2017, 09:15 PM
Jferrante
Jferrante's Avatar
best additive in the ford community
Amazon Amazon
-i use it every fill up. am going to try the stabil for one and see if i get the same results.
If i don't use the additive my gas gauge doesn't read so I at least know its cleaning the debris off the sender.
Old 04-05-2017, 02:13 PM
GPA951s
GPA951s's Avatar
Any good product like stantadyne which is found at any truck stop will work. With your year truck you should be using an additive every tank, I put Injectors in my LB7 Duramax and why they fail is due to the lack of sulfur in the fuel, They need a lubricant, I did the work myself and the injectors were 2k just for the eight..
Old 04-30-2017, 10:22 PM
The DareDevil
The DareDevil's Avatar
Haven't used any additives, but I'm filling up exclusively with Shell's V-Power diesel.
Quick Reply: Anyone using a diesel fuel additive?
