Has anyone used a rectangular storage box on the front of the trailer? - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 01-29-2017, 05:26 PM   #1
RickBetterley
RickBetterley's Avatar
Default Has anyone used a rectangular storage box on the front of the trailer?
Most installations are the trapezoidal-shape that follows the a-frame. This is to lessen the chance that the tow vehicle will strike the storage box on sharp turns. But you lose storage area as a result (compared with rectangular shape).
It seems very unlikely that my truck would hit ever a rectangular box, as the weight distribution hitch spring bars only allow a box that is 17" front-to-back.
I'm curious whether anyone has experience with using say a 40" wide rectangular box compared with a trapezoidal box. I've mocked this up and can't see how I would ever have a tight enough turn to interfere with the box.
Thanks for suggestions and insight.
RickBetterley is offline   Reply With Quote
Old 01-30-2017, 07:23 AM   #2
MJP911
MJP911's Avatar
I have a rectangular box typically used in pickup beds mounted to the front of mine - no problems.
MJP911 is offline   Reply With Quote
Old 01-30-2017, 09:10 AM   #3
RickBetterley
Quote:
Thanks for this; I was thinking along the same lines.
Would you mind telling me the width and depth (front to back) measurements for the box you use?
Old 01-31-2017, 09:02 PM   #4
Philip944
Philip944's Avatar
I've got a rectangle box on the front of my open trailer. I used to have it mounted as far back as possible. Doing so didn't give me enough tongue weight so I had to move it forward to allow the car to come forward a bit on the trailer. Moving it forward cost me a taillight and bumper touch up paint. I just got greedy with my reversing turn radius.
I suggest coupling the trailer and backing up to maximum trailer vs truck angle then setting your box on the tongue to see where you can safely mount it. I would also do so with the car on the trailer in its typical location.
I do like the bigger box on my open trailer but it did cost me a bit of hassle and I learned a lot during the first few tows.
Philip944 is offline   Reply With Quote
Old 02-07-2017, 12:26 AM   #5
kgorman
kgorman's Avatar
I pondered the same for some time, then ended up doing this:
It wasn't too expensive at HD.
This allows me full turning radius, the tongue jack to be used, and doesn't give up too much space. I keep trailer tools, chocks, tie downs, etc in it.
That said, I need an additional box to support the Cup. Still pondering that design..
kgorman is offline   Reply With Quote
Old 02-08-2017, 11:54 AM   #6
PLNewman
PLNewman's Avatar
I have a storage box (make sure it opens facing rearward) and three fuel jugs on the front of my open trailer.
PLNewman is offline   Reply With Quote
Old 02-26-2017, 11:46 AM   #7
Martin S.
Rennlister Extraordinaire
Martin S.'s Avatar
Smile Tractor Supply trapezoidal-shape box
I had one of these, good for bulky items such as jack stands....
http://www.tractorsupply.com/tsc/pro...lbox-371-cu-ft
Martin S. is offline   Reply With Quote
Old 02-27-2017, 12:30 PM   #8
AudiOn19s
AudiOn19s's Avatar
Mine has a rather large box on the front and it's never been an issue. If I allowed the truck to go to full jackknife when backing up the box would hit the truck but I'd have to be pretty crossed up for that to happen. Going forwards I can go to full lock and drive in a circle without interference.
AudiOn19s is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Any ideas for temporary car covers forhamilton 991 GT3 GT3RS and 911R 4 04-08-2016 08:37 PM
Becker Europa TG-M-U in 356C phiba 356 Forum 1 06-09-2014 12:11 PM
Carbon Canister Disassembly?? Musclehedz101 997 Forum 3 12-27-2012 03:39 PM
1986 951 Have "knock control diagnosis plug"? Player0 944 Turbo and Turbo-S Forum 5 10-08-2012 08:09 PM
X Post. Anyone got any front door speakers? 333pg333 924/931/944/951/968 Forum 5 12-20-2009 08:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
