Tire pressure gauge > 60 psi
Anybody have a recommendation for a tire pressure gauge that can go higher than 60 psi? Preferably up to 100 psi.
This is for setting truck and trailer tires. Most are 0-60 which won't work. Thanks.
Received 5,388 Likes
Every time a question is asked about a quality tire pressure gauge, you always see responses regarding Longacre, so maybe check there.
i use this for my truck and trailer tires:
https://www.napaonline.com/napa/en/p/TWRGA165/
Truck runs at 100-110 depending on axle and trailer tires are at 125.
It matches my TST pressure monitoring system within a pound.
It's a Volvo semi-tractor (registered as an RV) and a Pace GT trailer with 17.5" wheels.
Based on the weight charts I could run the drive tires on the Volvo under 80 PSI but that scares me.
I got tired of dealing with multiple gauges due to different ranges needed and have gone digital. I find the most useful gauge to be a nice digital display on the inflator. For the truck and trailer I have a TPMS, so I know what the pressures are roughly before I pull out the inflator to address the issue. I hated only have a 60 psi gauge (Longacre) on the inflator and having to use a different gauge to measure what the pressure was. Here's what I have: https://www.amazon.com/gp/product/B00CG674GY/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
I actually ended up buying 2 - one in the trailer with the nitrogen tank and one at home for the portable compressor.
I bought a digital Longacre that works in that range. Compared it to the $35 brass integrated tire filler/gauge from Napa auto. No difference. The Napa gauge was just as accurate. Save the money and buy a basic gauge.
