Intech vs ATC aluminum trailer
#46
Yes, not sure but why would a seller OVER-state the weight of his trailer? I've also heard it elsewhere that tricked out aluminum 24' trailers (with insulation, cabinets, beefier axles, etc.) weigh around 4000lb. Equivalent steel maybe few hundred lb more, if that. This is all anecdotal so would love to see and compare some actual scale weight numbers.
#47
Out of interest, have you put your CH305 on weight scales and compared the number with their estimate?
That may be hard because to be fair and accurate you'd have to find a manufacturer that builds the same model in both aluminum and steel
#48
dogger, that's helpful. Thx!
#49
When you buy an InTech they weigh it and include the sheet showing how much it weighed at delivery.
I thought this thread was about ATC vs Intech, not about steel vs aluminum. I bought an Intech because I priced both and got a slightly better deal. I also looked at a bunch of trailers in the paddock, mostly focusing on the ATC. Don't get me wrong, they are one of the best aluminum trailers, but the finish quality on the Intech just outclasses it. Every joint is perfectly mitered. If you look closely at the fine details you'll see what I mean. It's a work of art.
I also wanted the aluminum floor. The rubber coin floor didn't seem like a good idea to me. It didn't seem like it would be easy to clean up if you had an oil leak or something.
I've only had it for a season but have loved it. No regrets. If I ever decide to sell it and upgrade to a bigger one, I expect to get a good resale value.
#50
Here is what I needed to ....
...get the Credit Union to sign off. You will note the shipping weight is duly noted as 3,010.
The trailer would have been lighter had I not opted for :
-16" wheels with 235/80 tires + a spare VS lighter 15" wheels and a spare,
-Battery for potential winch,
-Shore power electronics,
-Twin scissor jacks in the rear
-48" passenger side entry door VS standard 24" door...24" too small,
-DOOR - ESCAPE - PREMIUM - 88" X 66" - TOP HINGE - FLUSH LOCK - REMOVABLE WHEEL WELL, ALUMINUM STEP
ONE PIECE REMOVABLE INTERIOR WHEEL WELL
Becker, Las Vegas was the dealer, trailer has a Quest Part#, and a signature from Aluminum Trailer Corporation. All seems a bit complicated, really not the case, seamless, and the quality of the trailer build, classy.
#51
Martin, what lenght and did it have any cabinets?
#52
20 FT trailer, and no cabinets, although the interior is completely finished, both walls and ceiling. I did add some extras, notable the 235/80/16 monster tires and aluminum wheels + spare of the same composition.
The Drivers side escape door (Multi Purpose) is what sold me.
#54
Thx. That escape door looks great. Great for a paddock shade and a cross-breeze. Every trailer should have it.
#55
Both Intech and ATC offer the basic (cheapest) plywood flooring. Intech claims that they have a standard aluminum underfloor layer to protect the plywood from the elements. Does ATC have the same or is the plywood just paint-protected underneath?
Martin, how is this on yours?
#56
#57
For those looking to shave weight, the Aluminum floor is a couple of hundred pounds lighter than the plywood/coin rubber.
#58
Re aluminum floors.
My CargoPro had the nice bright aluminum floor and I couldn't imagine wanting a rubber coin floor.
But my new-to-me HaulMark came with the coin, and I like it. Nice to not have the bright sun reflecting in my eyes and the slipperiness.
I am surprised that I prefer the coin but those new aluminum floors sure are pretty.
#59
Looking at the options I added to my Intech, on top of what they include in their iCon package, here are the things I really appreciate having:
1. Insulation and air conditioning. I'm in Texas - enough said. Although if it's 90+ degrees and sunny, the A/C can't keep up, so I don't bother using it at that point.
2. Wireless, in floor winch, with rope instead of steel. Loading up the car is so much easier.
3. Power tongue jack.
4. Two folding tire racks mounted on the walls. I wish I would have added a third.
5. Two spare tires mounted on the walls at the rear of the trailer, high up on the walls. This means I always have easy access to the spares, compared to them being in the floor, and I really prefer to carry two spares because losing one tire can often take out the other on that side. Fortunately, I've never had a flat on this trailer.
6. Two lines of airline track running down the length of the floor. This makes it very flexible to secure different length cars, as well as other items.
I also have a manual awning and really like it, but I haven't had to use it that often.
