Made In The USA Trailer Tire
Old 10-04-2016, 06:42 PM
dogger15
dogger15's Avatar
Default Made In The USA Trailer Tire
Goodyear is ramping up production on a new and improved trailer specific tire called the Endurance ST. The tires will be made in the U.S. and carry a speed rating of "N" or 87 mph. Not much info out about sizes other than 16 and 17" diameters will be the first produced.
I don't know if this tire will be marketed along side the now made in the U.S. Marathons, or is intended as a replacement.
I also got a good tip from a friend in the industry about another trailer tire I wasn't aware of called the Michelin XPS Rib. It's listed as an "LT" but the manufacturers states it's an "all position" tire which means Michelin certifies it for use as a trailer tire. It comes in load
range "E", is speed rated to 75 and is re-treadable.
Both sound like a step in the right direction.
Old 10-05-2016, 09:32 AM
Kein_Ersatz
Kein_Ersatz's Avatar
Hope they make smaller rim diameters (15/14) at some point for Trailex and such.
Quick Reply: Made In The USA Trailer Tire
