Brake Rebuild
Brake Rebuild
I'm going to rebuild all calipers this Spring. What are people using? I've read that some of the aftermarket products don't perform well. In my search I've been unable to find a Brembo/OEM kit. Racing Brake has the components. Anyone have experience with their kits?
Hoerr Racing also offers individual gaskets/seal that are labeled as Brembo.
http://www.hrpworld.com/store/defaul...seal-each.html
Thanks for the help.
I rebuilt mine a couple seasons ago. Here are the Brembo part numbers.
05595552 - Piston Seal Brembo 28mm
05595553 - Piston Seal Brembo 30mm
05595556 - Piston Seal Brembo 36mm
05595558 - Piston Seal Brembo 40mm
Rennlist Hoonigan
which cost no drachmas
I've had bad luck with the Centric the last few years. The smaller seal is the wrong size and makes putting the smaller piston in next to impossible. I would say to go with the HRP seals. That is what we've used with good luck.
